FS:Definitive Technology BP30 Tower Speakers
tboo72
I have a pair of Definitive Technology BP30 floor standing speakers for sale. These are very hard to find. They are the big brothers to the BP10 series but were discontinued several years back. These are monster non-powered speakers. Mine are in great condition & work and sound great. End caps & socks are in good shape. They weigh 80lbs a piece and are rated up to 500W a channel. Asking $500 firm for the pair. I do not have the original boxes so don't ask me to ship. Local pickup only. I'm located in NE Wisconsin. PM me with questions.
Post edited by tboo72 on
if u can't sell local i'd b interested but live in phx az-602-459-2564 thx billy
If you were within 3-4 hours of me Id have to pick these up... lol- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Yeah, sorry guys but these are just too big & heavy to ship. It would cost a fortune.
It wouldnt cost as much as you think --
I shipped a set of BP20 (same coast) for about 100 bucks total...
Packing material is cheap ($25.00) for a 4'x8' sheet of 2" foam at lowes... piece mill a box - tape it up real good, shipping would be 30ish a box on the same vertical plane on a map and double cross country...
So yeah, not to shabby - just saying.
BP20 are the same size, dimensions, etc of the BP30- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
keep me in mind-i'm still interested!
So whats the difference between the 20 and 30? just courious.Musical Fidelity Tri-Vista 300, Audioquest Thunderbird Zero Speaker Cable, Tyler Highland H2, Audioquest Thunderbird Interconnect, Innuos Zen MK3 W4S recovery, Revolution Audio Labs USB & Ethernet, Border Patrol SE-I, Audioquest Niagara 5000 & Thunder, Cullen Crossover II PC's.
Good question. I didn't even realize there was a BP20 till a few days ago. -
The BP 30 had a better tweeter than the BP 20. I believe the 6.5" MW's were the same, as was the cabinet."Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer
Not quite - and actually quite a bit...
1) The tweeter and woofers are both Definitive in the BP30 - the BP20 used a Vifa soft dome tweeter and a Vifa midbass which is now made by Scanspeak... I would say both of the Definitive drivers are a step up in alot of regards....
2) The port on the BP20 is just a regular port
3) The port on the BP30 is a quasi transmission line where they recess it in the cabinet with an oval cutout about 3 times the size of the port exit diameter, thus causing it to load like a transmission line thus increasing bass by about 3-4db in the low end... and allowing it to dig a few octaves deeper.
4) The cabinet on the BP30 is built far superior and there is a solid board that spans the inside of the cabinet separating the inside and outside woofers from each other where this is not the case in the BP20
The BP30 is a rightful heir to the throne that was the BP20 - the original BP line was when Definitive was just getting started and you can tell they did not have near the resources as they did later on.
Also the crossovers are far superior in the "B" line the BP30 was associated with.
Hope this helps.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Hope this helps.
Wow! Didn't know all that. Thanks for posting it."Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer -
Yep, no problem -
I also believe the B line was the first to use Medite in the front and back panels (much denser than MDF) - however they still used particle board on the sides (3/4) and top/bottom (1/2") - the enclosure is braced far better in the B line as well...
The 20 just has 3 or 4 randomly placed braces...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Thanks for the info VR3!
So the 30 is like the 20's on steroids! LOl
I liked the 20's. they were a darn good speaker espeically with the crossover upgrade vr3 did to them.
So the 30's might dig a little deeper and have more of a sizzle on the top end vs the 20 if i am reading it right?Musical Fidelity Tri-Vista 300, Audioquest Thunderbird Zero Speaker Cable, Tyler Highland H2, Audioquest Thunderbird Interconnect, Innuos Zen MK3 W4S recovery, Revolution Audio Labs USB & Ethernet, Border Patrol SE-I, Audioquest Niagara 5000 & Thunder, Cullen Crossover II PC's. -
I can confirm the 30s dig very deep. -
The 30 should have far better high end and upper midrange clarity.. making it an overall "brighter" speaker where as the 20 will be more relaxed...
Really depends on your preference. Both are great speakers that can simply throw down and melt your soul through vibrations haha- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
bump
bump
If you are still having trouble selling them locally send me a PM. I live in Rochester NY and wouldn't mind giving you a bit more if you went through the trouble of packing them for shipping.
-Tony -
same here
by the way-do u have the carpet spikes
Yes, I have carpet spikes on them.
Road trip worthy for sure!!!!!!!!
I would get a divorce notice though if I told her I was going to get them. She just doesn't know how nice these are. My second newer pair of BP 10's are INCREDIBLE. I can only imagine what your BP 30's sound like.Maybe the BIG SRS POlks come to mind.Most people just listen to music and watch movies. I EXPERIENCE them. -
I live on the west coast of Lake Michigan and this is certainly getting tempting....How far from 53083 are you?
About an hour drive north. Im at 54915. -
bump
i live in southern michigan would u be willing to meet part of the way to cut down on my drive time , i dont know how to pm so i am not familiar with how to get in touch with someone on this forum ,
just to ad a note if the drive time is less than 5 hrs i can leave on tuesday the 17th or wed. the 18th
I sent you a PM. Let me know if you can read it. -
i ca read it but i cant respond because i do not have enough posts , this will be my 3rd .... i need 10
