Polk 7A's... are they worth fixing?
  • Conradicles
    Conradicles Posts: 6,343
    edited January 2012
    For this upgrade I wanted to keep costs as low as possible since these are going to be garage monitors. Jantzen had the exact value caps, and Mundorf resistors fit the bill. Also replaced the internal speaker wire and fuses.
    They are breaking in now.:smile:
  • michael1947
    michael1947 Posts: 775
    edited January 2012
    Yes. Fix 'em. Use them in the garage or pass them along to someone in need.
    Main Family Room: Sony 46 LCD, Sony Blue Ray, Sony DVD/VCR combo,Onkyo TXNR 708, Parasound 5250,
    Living Room: Belkin PF60, Parasound HCA2200, MIT ProlineEXP balanced IC's,Emotiva XDA-1 DAC/Pre,Emotiva ERC2 transport,MIT AVT2, Polk LSI 9's.
  • TNHNDYMAN
    TNHNDYMAN Posts: 2,145
    edited January 2012
    Eric,
    Looking great man! Hope they sound even better than before. Offer on 6500 mid still applies if you need it let me know.
    Travis
  • gdb
    gdb Posts: 6,012
    edited January 2012
    "Yes. Fix 'em. Use them in the garage or pass them along to someone in need."
    Wowzer, thats profound.:smile:
  • Oldfatdogs
    Oldfatdogs Posts: 1,874
    edited January 2012
    Conradicles, I have a question for you. On your caps 33uf it says 400v on TrashyTrucker post for his cap are 200 vdc can you tell me what the difference is?
  • Conradicles
    edited January 2012
    Oldfatdogs wrote: »
    "What does the Voltage Rating on a Capacitor Mean?
    The voltage rating on a capacitor is the maximum amount of voltage that a capacitor can safely store.
    Remember that capacitors are storage devices. The main thing you need to know about capacitors is that they store X charge at X voltage; meaning, they hold a certain size charge (1?F, 100?F, 1000?F, etc.) at a certain voltage (10V, 25V, 50V, etc.). So when choosing a capacitor you just need to know what size charge you want and at which voltage.
    Why does a capacitor come in different voltage ratings? Because you may need different voltages for a circuit depending on what circuit you're dealing with. Remember, capacitors supply voltage to a circuit just like a battery does. The only difference is a capacitor discharges its voltage much quicker than a battery, but it's the same concept in how they both supply voltage to a circuit. A circuit designer wouldn't just use any voltage for a circuit but a specific voltage which is needed for the circuit. For one circuit, 12 volts may be needed. A capacitor with a 12V rating or higher would be used in this case. In another, 50 volts may be needed. A capacitor with a 50V rating or higher would be used. This is why capacitors come in different voltage ratings, so that they can supply circuits with different voltages, fitting the power (voltage) needs of the circuit.
    Take note that a capacitor's voltage rating is not the voltage that the capacitor will charge up to, but only the maximum amount of voltage that a capacitor should be exposed to and can store safely. For the capacitor to charge up to the desired voltage, the circuit designer must design the circuit specificially for the capacitor to charge up to that voltage. A capacitor may have a 50-volt rating but it will not charge up to 50 volts unless it is fed 50 volts from a DC power source. The voltage rating is only the maximum voltage that a capacitor should be exposed to, not the voltage that the capacitor will charge up to. A capacitor will only charge to a specific voltage level if fed that level of voltage from a DC power source.
    Keep in mind that a good rule for choosing the voltage ratings for capacitors is not to choose the exact voltage rating that the power supply will supply it. It is normally recommended to give a good amount of room when choosing the voltage rating of a capacitor. Meaning, if you want a capacitor to hold 25 volts, don't choose exactly a 25 volt-rated capacitor. Leave some room for a safety margin just in case the power supply voltage ever increased due to any reasons. If you measured the voltage of a 9V battery supply, you would notice that it reads above 9 volts when it's new and has full life. If you used an exact 9-volt rated capacitor, it would be exposed to a higher voltage than the maximum specified voltage (the voltage rating). Usually, in a case such as this, it shouldn't be a problem, but nevertheless, it's a good safety margin and engineering practice to do this. You can't really go wrong choosing a higher voltage-rated capacitor than the voltage that the power supply will supply it, but you can definitely go wrong choosing a lower voltage-rated capacitor than the voltage that it will be exposed to. If you charge up a capacitor with a lower voltage rating than the voltage that the power supply will supply it, you risk the chance of the capacitor exploding and becoming defective and unusable. So don't expose a capacitor to a higher voltage than its voltage rating. The voltage rating is the maximum voltage that a capacitor is meant to be exposed to and can store. Some say a good engineering practice is to choose a capacitor that has double the voltage rating than the power supply voltage you will use to charge it. So if a capacitor is going to be exposed to 25 volts, to be on the safe side, it's best to use a 50 volt-rated capacitor."
  • Oldfatdogs
    edited January 2012
    Thank you sir.
  • Conradicles
    edited January 2012
    These things sound soooooo much better with the crossover upgrade. They mate very well with the NAD components. I moved them out a bit further than they were in the pictures. Amazing speakers.:cool:
  • chandler9a
    chandler9a Posts: 878
    edited January 2012
    awesome set up man. My father had his 1.2TL xovers done with Jantenz caps, Im sure there are better but they sound very nice so far...
    Not a bad garage set up at all.
  • TNHNDYMAN
    edited January 2012
    Glad you got them upgraded. Now you need to get a set of 10's :)
  • Tour2ma
    Tour2ma Posts: 10,177
    edited January 2012
    chandler9a wrote: »
    LOL... May be the only garage rig I've ever seen with acoustic treatments...
    More later,
    Tour...
    Vox Copuli
  • Conradicles
    edited January 2012
    Tour2ma wrote: »
    I actually put up egg crate style foam (I get it free from work) all over the whole garage. It looks like a huge anechoic chamber.:eek:
  • Tour2ma
    edited January 2012
    ... and it looks like a great place to sip a cool one on a warm, Spring afternoon... with an egg-salad sandwich... :cheesygrin:
    More later,
    Tour...
    Vox Copuli
  • reedg01
    reedg01 Posts: 1
    So I too have a pair of 7A's that I purchased new, right here in Baltimore where they (used to be) made. I haven't had them in service for a while, as my SIL worked there in the early 2000's and I got a Friends and Family deal on some RT200i's.
    My younger son expressed an interest, so I came (back) here to see what would make sense and found this thread.
    Seeing as how people are recommending the original drivers, as opposed to sourcing new replacements from Polk, I decided to open one of mine up and take a look.
    http://i1222.photobucket.com/albums/dd497/reedg01/Mobile Uploads/20160523_201316_zps263ph4u4.jpg
    I now see the insulation I have been reading about, I thought it would be wide open so the Mid could pump the Passive Radiator, but that's obviously not the case.
    Here's a shot of the front beforehand:
    http://i1222.photobucket.com/albums/dd497/reedg01/Mobile Uploads/20160523_200817_zpskkc9uyty.jpg
    and here's the back of the MW -
    http://i1222.photobucket.com/albums/dd497/reedg01/Mobile Uploads/20160523_201346_zpspi11ky3o.jpg
    Obviously, the gasket material between the Mid driver basket and the speaker body itself has gone bye bye, so I will need to replace that. (With what? Sourced where? This inquiring mind wants to know!)
    The Mid moves freely and the surrounding portion that returns the driver to its starting position seems to still be doing it's job.
    Recommendations from the collective?
    Thanks in Advance.
    Glenn
  • boston1450
    boston1450 Posts: 7,758
    Not sure if you mean this = You can go to HDepot & buy Armaflex Armacell in a roll & cut strips. Mark where your screw holes are & poke thru before you put screws in-so it doesnt twist up.
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
  • boston1450
    edited May 2016
    While your at it - if you havent already done this.... Buy a tube of Loctite Power Grab (usually 3.00 a tube) apply a bead around EACH side of the magnet on each woofer. This will help protect the magnet from shifting. The old glue on the magnets are sure to be fragile & easily ready to shift at any time
    Randy-Maine
    by David WMG
