My first DIY cables
themuskr
I didn't have anything for the girlfriend to get me this christmas so i decided to have her get me the parts for DIY cables. I needed something to occupy me so this was perfect. I got some Belden 5000UE cable, cable pants, techflex, heat shrink tube, and banna plugs. I got the cable from BJC and the rest from parts express. This project turned out to be easier than i thought it would be. I cut the cable to length, stripped it and tinned the ends. Add a little heat shrink and techflex and it looks professional!
I also got a new fun tool in the process, a Bernzomatic mini torch. it had everything i needed; hot knife soldering tip, and heat shrink melting tip. Worked Perfect!
and now pics! I don't think i did too bad for being my first crack at it.
One end isn't terminated because i have BJC bannanas at school with my system
2 Mirage OMD-5's (burled Maple)
1 Mirage OMD-C1
4 Mirage nanosat MX
Mirage MM-6
Def Tech Prosub 100
Pioneer Elite vsx-40
BJC cable
1 Mirage OMD-C1
4 Mirage nanosat MX
Mirage MM-6
Def Tech Prosub 100
BJC cable
Post edited by themuskr on
Nice work.
Looks great!
Monster AVL-300, HTS-2500 MKII -
Nice job!
Thanks guys. They turned out much better than i thought they would.2 Mirage OMD-5's (burled Maple)
1 Mirage OMD-C1
4 Mirage nanosat MX
Mirage MM-6
Def Tech Prosub 100
BJC cable -
You've inspired me to give this a go. How hard was it muskr?
Very nice, if u don't mind, what was the cost per foot not counting the torch?Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable -
It was easy if you are a modest DIY'er2 Mirage OMD-5's (burled Maple)
1 Mirage OMD-C1
4 Mirage nanosat MX
Mirage MM-6
Def Tech Prosub 100
BJC cable -
soundfreak1 wrote: »Very nice, if u don't mind, what was the cost per foot not counting the torch?
It was about $50 all said and done, and i have not had a chance to listen to them because i am away from my system until the ninth2 Mirage OMD-5's (burled Maple)
1 Mirage OMD-C1
4 Mirage nanosat MX
Mirage MM-6
Def Tech Prosub 100
BJC cable -
How long dis make themMain Rig:
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
they are about 12 ft long2 Mirage OMD-5's (burled Maple)
1 Mirage OMD-C1
4 Mirage nanosat MX
Mirage MM-6
Def Tech Prosub 100
BJC cable -
Nice work! I have so much of that stuff at my house but I never seem to get the time to make any cables
I know what you mean! it took me a few years to get tired of cutting of oxidized cable ends.2 Mirage OMD-5's (burled Maple)
1 Mirage OMD-C1
4 Mirage nanosat MX
Mirage MM-6
Def Tech Prosub 100
BJC cable -
Nice Job on your cables! DIY can be lots of fun, and save lots of money! :biggrin:Sunfire Theater Grand IV
SRS 2.1TL
SDA 2BTL's
CSiA6
FXiA4
FXiA6
SDA 2A's
Monitor 10A's
http://www.douglasconnection.com -
helipilotdoug wrote: »Nice Job on your cables! DIY can be lots of fun, and save lots of money! :biggrin:
Thanks, I love making things myself. Saving money is great too!2 Mirage OMD-5's (burled Maple)
1 Mirage OMD-C1
4 Mirage nanosat MX
Mirage MM-6
Def Tech Prosub 100
BJC cable -
They look great! What size tech flex did you end up using with the Belden 5000UE?AVR - Yamaha Aventage RX-A800
Amps - B&K Components ST2140 (for mains) and Parasound HCA-1000A (bi-amping center)
Mains - RT1000i Towers
Center - CS400i
Sub - BIC Acoustech PL200
My neighbors listen to very good music, whether they like it or not :cheesygrin: -
it's 3/8" It was a perfect snug fit!2 Mirage OMD-5's (burled Maple)
1 Mirage OMD-C1
4 Mirage nanosat MX
Mirage MM-6
Def Tech Prosub 100
BJC cable -
Thanks! Im going to order my stuff now
Center - CS400i
Very good idea, I need to add that to the honey-do list
