normal vs truck box
jablonep
I have a yukon but need my back floor space for equipment. I ordered the truck style box instead of normal square but both are .65cu. The speakers are infinity 10.1d 10" subs, is this ok or should I send the boxes back.
is it the recommended size for the subs?
since the rec'd volume is .6, you'll be fine.It's not good, very fundamentally simply not good. - geolemon
This is the recommended size, I just wasn't sure if the sound from a truck style box is inferior?
nopeIt's not good, very fundamentally simply not good. - geolemon
