Optimizing TSi500 Setup
tmartin
tmartin Posts: 6
edited December 2011 in Speakers
Hey there,
Want to get the most of out my new home theater setup, looking for FEEDBACK/RECOMMENDATIONS.
Is my Pioneer VSX-1020-K enough to power my setup for music, movies, and games? I've been reading about
owner's adding AMPs and Pre-AMPs to their systems for extra power, ie. Emotiva.
Feeling that my fronts are still flat when listening to FLAC music files, haven't tried CD's or Vinyls.
Please help, thanks.
TM
Sony KDL-60NX810
Pioneer VSX-1020-K
Polk TSi500 (2)
Polk CS10
Polk FXi A4 (2)
Polk PSW505
Logitech Harmony One
Post edited by tmartin on
  • Stilly74
    Stilly74 Posts: 194
    Think your amp should push around 80 watts per ch. I'm using a denon891 (105 watts per/ch) and pushes the tsi500's very well. Sound great in a 7.1 setup or in 2ch setup with a velodyne eq-max12 sub. Well they did sound great till recently found that the tweeters are blow in both speakers. Not sure how this happened but...... Have them paired with tsi 200 and tsi100. Could not be happier with the setup.
  • wutadumsn23
    wutadumsn23 Posts: 3,702
    I am not overly familiar with Pioneer AVR's but if I am not mistaken this particular model does not have Pre Amp inputs? Without those, adding an external amp would not be possible.... Hope I am wrong.
    -Jeff
    HT Rig
    Receiver- Onkyo TX-SR806
    Mains- Polk Audio Monitor 70
    Center- Polk Audio CS2
    Surrounds- Polk Audio TSi 500's :D
    Sub- Polk Audio PSW125
    Blu-Ray- 80 GB PS3
    2 CH rig (in progress)
    It's not that I'm insensitive, I just don't care.. :D
    tonyb Posts: 33,066
    The receiver you have is fine for the speakers you have, unfortunately though your limited to what you can upgrade to down the road because you don't have preouts. That said, flac sounds terrible run straight into most entry level receivers, heck, even more advanced receivers too. You need a stand alone DAC to run your flac into, then analog outputs into the avr inputs. This would improve your sound 5 fold. We have many threads going on how to get decent sound out of downloaded music, use the search function and read up. Also, if your speakers are sounding flat or dull, it could be you have something setup wrong in the receiver. First thing to look at is where the speaker levels are set too, and the crossover settings, both in the avr and the back of the subwoofer.
    Stilly74- You blew your tweeters likely from over driving them at higher volumes. Your receiver and the OP's is not rated for those watts at 5.1 or even worse, 7.1.....more like 30-40 watts in surround mode. Everything has it's limits.
  • wutadumsn23
    Thanks Tony, I meant pre outs, lol. Long night.
    -Jeff
    HT Rig
    Blu-Ray- 80 GB PS3
  • tmartin
    tmartin Posts: 6
    Thanks all the responses, I appreciate it.
    Tonyb, could you recommend a decent mid-range DAC I could pickup, and point me to where I could learn how to set this up?
    Here a the specs of both the receiver and fronts.
    VSX-1020-K
    POWER
    Amplifier Design - Direct Energy
    Channels - 7.1
    Power Output Per Channel(20Hz-20kHz,.08%THD@8ohm) 80
    Power Output Per Channel (1kHz@8ohm) 110
    Power Output Per Channel (1kHz@6ohm) 125
    TSi500
    Electrical
    Overall Frequency Response 28Hz-25kHz
    Lower -3dB Limit 38Hz dB
    Upper -3dB Limit 24KHz dB
    Nominal Impedance 8 ohms
    Recommended Amplifier Power 20-275 w/channel
    Efficiency 91 dB
    Crossover 2500
    Inputs 5 way binding posts
    Seeing as how my AVR can only hit 125 w per channel, will using a DAC push closer to the 275ish range? Will that make sound quality better?
  • thsmith
    thsmith Posts: 6,082
    tmartin wrote: »
    Hey there,
    TM
    Sony KDL-60NX810
    Pioneer VSX-1020-K
    Polk TSi500 (2)
    Polk CS10
    Polk FXi A4 (2)
    Polk PSW505
    What are you running your FLAC files through before getting to avr and how are you feeding the avr.?
    While I was waiting on my w4s DAC 2 I played aiff files from my Mac mini hdmi to avr and it did not sound flat, thin but did have a little depth. Obviously the DAC 2 sounds excellent but I admit to being surprised how well it sounded using avr.
  • tmartin
    tmartin Posts: 6
    I'm using my iPod/iPhone. Perhaps flat was the wrong word to use, but when I listened to music I'm still thinking that it could sound better from the TSi's. Not sure if that's just the limitation of my mid-range setup itself, or if I need to tweak things (quite new at this, so trying to learn and figure things out). Thanks.
  • thsmith
    tmartin wrote: »
    Your I devices are not playing flac, most likely mp3. Try aiff and see if that sounds better.
  • B Run
    B Run Posts: 1,888
    Keep in mind it's not delivering near as much power as you think. The 1120 which has beefier amps only pushes 47wpc when running 5 channels, and the 1020 is advertised with 30 less watts than the 1120. I think you need a new receiver to get the sound you want.
    If you're on a budget the Music Fidelity V-DAC is a nice starter unit that has gotten some nice reviews and is not horribly expensive. If you get into what the guys around here use! Be prepared to spend a 1000 plus on a DAC. That's just not in my budget!
    Good Luck!
    cnh
