Center/surrounds to match a set of Model 10 fronts?
I'm not in front of them right now, but I had written this down from the back:
Polk Audio Monitor Series 10 206821
What would be recommended as a center to match? I'm not as concerned about voice-matching the rears, but I would guess I need to pick up a set of bookshelf speakers that also use the same tweeter and just use one as the center? I'm just concerned about the center being at a different height and also the magnet interfering with my screen? Thanks for the input!
Post edited by codycr6 on
The CS350LS is usually the recommended center for vintage Polks short of a single of whatever you have. Mag shielding is not an issue unless you're still running a CRT for your TV... -
Here's some advice from Polk University:
http://www.polkaudio.com/education/showanswer.php?question_num=63 -
Any idea what generation these are? Up for sale, and trying to decide whether to jump on them!!!!
I tried to look up the CSIA6, but I found nothing on them on Polk's vintage area?
Because it's not vintage...I tried to look up the CSIA6, but I found nothing on them on Polk's vintage area?
http://www.polkaudio.com/homeaudio/rtia/index.php?s=csia6
