Capacitor recommendation
heiney9
heiney9 Posts: 25,432
edited January 2012 in DIY, Mods & Tweaks
It's really a simple question. I really like Auricaps and Clarity Caps for my use in cross-overs and coupling caps. Thought on my next project I might try something different. I am on a budget and these are budget speakers so I am not going all out.
I have a pair of Polk RT25i's that I will re-cap and add Mills resistors.
I was going to go with the The Clarity PX line for the high pass just like I did on my 5B's. I am purchasing Dayton Caps for the low pass and the Mills from Parts Express and they don't carry Clarity which means an order from another vendor and extra shipping.
PE has the Jantzen Cross Cap in a value I can use, it's not exact but by combining two values I can come very close. The RT25i's have an 8uF electrolytic bypassed by a 1uF mylar so there are 2 opening on the board. I can use (2) Jantzen Cross Cap 4.7uF for a total of 9.4uF in the high pass.
OR
I can order a 9uF Clarity PX from Madisound.
1) People who have listened to both brands which is the better sounding cap?
2) will the extra capacitance make a huge difference in sound? Better to just stick with a single 9uF?
Thanks and please don't recommend Sonicaps, I use those as well, but this is for a budget project, for a budget speaker that is used in rotation in my office rig.
Post edited by heiney9 on
  • NJPOLKER
    NJPOLKER Posts: 3,474
    edited December 2011
    This won't be much help but I will mention it anyway because thats the type of guy I am.
    My Sonus Faber Grand Pianos have the dreaded Bennic caps soooooooooooooooooooooooo. Just saying maybe just maybe they are a good option. By the way I am far from a cap expert :cry:
    pitdogg2 Posts: 27,035
    Why not try the Dayton 1%'ers Brock? just for kicks
    NJPolker, those are electrolytics. I won't use electrolytics in the high pass even if it's bypassed like the current RT25i crossover from the factory.
    Pitdogg, that is an option too.
    I can't justify double the price to go from the Clarity PX to SA line, I just don't see the value. I could go all Dayton. I know the higher end Jantzen get great reviews. What I don't want it a high end like Solen caps give. Gritty and a little shouty and not very refined.
  • deronb1
    deronb1 Posts: 5,021
    I have Bennics (high and low) in my 8Ts and they sound great IMO.
    I have all Daytons in a pair of small Pinnacle's that never sounded good stock. Still don't sound good even with new caps and resistors. I blame the poor tweeter than makes everything sound nasaly. They will probably be stuck in the closet eternally, they really are stinkers compared to what I'm used to. I guess I can't blame the new parts since they didn't change a thing.
  • Face
    Face Posts: 14,340
    I wouldn't use Dayton on the tweeter. If you use Jantzen, don't use their lowest line.
    Face wrote: »
    I believe the Cross Cap is their lowest line, the next in line is more than double. The more I think (and know) for the cost I think the Clarity PX is a nice sounding cap compared to others in the same category. I'll pay the extra shipping and order from two places.
    My other option is to bypass a cheaper cap, but I'm not sure in the end the extra expense is really worth it. I could leave the 8uF electrolytic in place and buy a nice 1uF bypass. Somehow I don't think that would be as good as just replacing both with a 9uF poly cap.
  • Joe08867
    Joe08867 Posts: 3,919
    Sounds like you made up your mind but for what it's worth get the Clarity PX.
    You will not be happy with the Daytons, and if budget is main concern on this upgrade the Clarity's are your best bet.
    BTW the Bennic Electrolytics are great sounding caps.
    Budget is a concern because if I'm not careful I'll have as much in x-over upgrades as I paid for the speakers. When in the hell did Mills resistors get so expensive? I need (4) @ $4.25, that's almost $18 in resistors!!!!!
    Really, a 0.48c - $1.50 Bennic electrolytic sounds GREAT? Why am I spending $7-$10 a piece on caps then if the cheapo electrolytics sound great?
    Ok, so this is what I've decided.
    2.0 Mills resistor and 9uF Clarity PX for the high pass
    keeping the stock resistor and replacing the electro with a 27uF Dayton for the low pass. Problem is I know the low pass really isn't that low and it will play a majority of the midrange, perhaps I should spring for the extra Mills resistors.
    Should bring me in right under $50 shipped from two different vendors. I wanted to stay right at $50 for a max. I had to delete the resistors for the low pass for a savings of $8.50 to hit my target.
    F1nut Posts: 51,749
    That's a rather large value for a bypass cap. You sure you read it right?
    I was assuming since the 8uF is an electrolytic and the 1uF is a mylar and they are in parallel. My assumption was they were trying to bypass the sound of the 8uF electrolytic. I could be wrong, but why put a large value in parallel with a small value and they are different types of caps?
    http://www.polkaudio.com/forums/attachment.php?attachmentid=18701&d=1155781569
    F1nut Posts: 51,749
    Yeah, I see what you mean, it appears to be a bypass alright. Hmmmm
  • FTGV
    FTGV Posts: 3,650
    Some contend that when budget is an issue, that by paralleling a "lytic" with a film cap of approx. atleast 10% it's value is enough to compensate for much of it's sonic shortcomings.This appears to be Polk's thinking atleast with this model..
    mhardy6647 Posts: 35,001
    The Dayton caps are Bennic OEM AFAIK.
  • FTGV
    FTGV Posts: 3,650
    I believe you are correct.
    VR3 Posts: 29,426
    PX and Mox resistors is an excellent combo that you can purchase from Madisound
    The more I think about it, I am on a budget because of the intended use so I will nix the Mills and go with the MOX resistors to save a little coin
    VR3 Posts: 29,426
    Definitely - not to mention I like Mox a little better than mills, they have a little more sparkle on the top end where as Mills is a little more neutral... so I guess it just depends on your intended sound goals.
    I personally prefer Mox in the applications I have used it in. I actually liked EAGLE over Mills as well as far as sound traits go - I do not find Mills to be that special other than just being a standard...
    YMMV
  • Joe08867
    Don't get me wrong on the Bennic's. They sound very good for an electro but not as good as the Clarity Poly. I still think the Clarity Caps are your best choice.
    F1nut Posts: 51,749
    VR3
    Ah, much better!
  • Conradicles
    Conradicles Posts: 6,340
    edited January 2012
    H9...today I used Jantzen Cross Caps and Mundorf MOX resistors in some Monitor 7A's...after a few days of break in I'll let you know what I think. The MOX is a good bit longer than the Mills, but has nice long leads.
