Any HVAC experts here? Honeywell Thermostat hysteresis
Serendipity
Was wondering if any HVAC experts could chime in on this problem: We have a Honeywell 7 day programmable thermostat with the "smart learning" feature that adjusts the run time based on the time it takes to heat the house (time from heater cycle to set temperature). Recently, the thermostat has been overshooting the set value and overheating the house several degrees, then allowing it to cool 2-3 degrees. Sometimes it will not even run the furnace for several hours after a long run cycle!
Is there any way to adjust the hysteresis of a Honeywell 32207626 programmable thermostat?
We have a steam system.
Thanks!
Thanks!
polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
Front projection, 2 channel, car audio... life is good!
Post edited by Serendipity on
Well, the unit is on a wall that's got nothing on 3 sides (you could call it a peninsula), and not near any exterior walls of the house. I pulled the thermostat off and couldn't feel any cold drafts coming through the wall. Yes, it has started doing this recently, and I was the original installer of the thermostat. Made sure that it's set to "Steam" instead of "Forced Air," recovery is set to "Auto", and I haven't messed with the service menu yet.polkaudio RT35 Bookshelves
Was there any home improvment going on to create alot of dust? The stat temp senser may be dirty. Blow it out carefully. If this does not fix the problem go into the sub program and "reset" the stat to its factory settings.Rec rm vm30 micro pro 3000 akai 2 channel. ht anthem MTX 5 channel anthem P2 statement anthem 325, 8 channel Martin Logan power amp for 4 ceiling ls900 2 and outdoor polks, 2 JL 110’s subs panasonic 65" plasma lsim 705’s , 706c, L200 and Control 4 garage rig monitor 10s crossovers by VR3, dynamat, RDO-194's, new drivers. psw 111 Pioneer 9040 BDP53fd 100 " screen Nakamichi HD projector, and Panasonic 65” plasma.
Honey mod # would help. I have info for all.Rec rm vm30 micro pro 3000 akai 2 channel. ht anthem MTX 5 channel anthem P2 statement anthem 325, 8 channel Martin Logan power amp for 4 ceiling ls900 2 and outdoor polks, 2 JL 110’s subs panasonic 65" plasma lsim 705’s , 706c, L200 and Control 4 garage rig monitor 10s crossovers by VR3, dynamat, RDO-194's, new drivers. psw 111 Pioneer 9040 BDP53fd 100 " screen Nakamichi HD projector, and Panasonic 65” plasma.
anonymouse wrote: »Ok... does the thermostat register the set temperature and still not shut off? i.e. if you set it to 70, does it just keep the heat going while the display reads 70, 71, 72 through 73 and then shut off?
Yes, but it doesn't change that fast. If you set it to 67, it will go up to 69 and at that point, all of a sudden it displays 70 and the heat shuts off.
Also no home improvement or dust in the house. I just pulled the unit off and cleaned it!
Not sure of the model number. Will find it.polkaudio RT35 Bookshelves
+1. The # listed doesn't come up at the Honeywell site. 3220 brings up the Chronotherm tstat's. Not 100% sure that's the right one?I refuse to argue with idiots, because people can't tell the DIFFERENCE! -
looking at the 'Adaptive Intelligent Recovery' feature of what I assume is your tstat, it's designed that way.I refuse to argue with idiots, because people can't tell the DIFFERENCE!
I think this is the problem. Is there a way to erase the "Adaptive Intelligent Recovery" memory?
If set to 67 degrees the stat doesn't even display 68, it will go from 67 to 69 and then before you know it the room temp is at 70 with the heat off!! The heat turns off only AFTER the display reads 69!polkaudio RT35 Bookshelves
I have Honeywell Thermostat also, and it does some weird also. When it recovers during cooling it also states the temp is 81f when if it was under 81f to start. Really weird, I have think its a bug in the software of that thermostat. Not sure if that is a problem with you but....
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
disneyjoe7 wrote: »I have Honeywell Thermostat also, and it does some weird also. When it recovers during cooling it also states the temp is 81f when if it was under 81f to start. Really weird, I have think its a bug in the software of that thermostat. Not sure if that is a problem with you but....
Exactly! At one point I had "Adaptive Intelligent Recovery" set to OFF, and I don't recall any of this strange stuff happening. With my early morning schedule, and having to leave sometimes at 6:50AM, I set the wake time very early this year. Much earlier than before where the delta between Cold --> Hot is much greater (i.e. 60 to 68 degrees).polkaudio RT35 Bookshelves
Is the t-stat a touch screen?Rec rm vm30 micro pro 3000 akai 2 channel. ht anthem MTX 5 channel anthem P2 statement anthem 325, 8 channel Martin Logan power amp for 4 ceiling ls900 2 and outdoor polks, 2 JL 110’s subs panasonic 65" plasma lsim 705’s , 706c, L200 and Control 4 garage rig monitor 10s crossovers by VR3, dynamat, RDO-194's, new drivers. psw 111 Pioneer 9040 BDP53fd 100 " screen Nakamichi HD projector, and Panasonic 65” plasma.
Nope.
Thinking back to when I installed it, I believe it may be an early (push button) version of the 7600 series.
Runs an embedded system, programmable, with "Adaptive Recovery" and LCD screen.polkaudio RT35 Bookshelves
I know what t-stat you've got- it's the HAL9000, "What are you doing, Dave?":cheesygrin:
Sorry. If you've lost the owners manual, you can get it off the Honeywell site. Either view it, or download it in PDF.I refuse to argue with idiots, because people can't tell the DIFFERENCE! -
Do you have a red manual and a white installers manualRec rm vm30 micro pro 3000 akai 2 channel. ht anthem MTX 5 channel anthem P2 statement anthem 325, 8 channel Martin Logan power amp for 4 ceiling ls900 2 and outdoor polks, 2 JL 110’s subs panasonic 65" plasma lsim 705’s , 706c, L200 and Control 4 garage rig monitor 10s crossovers by VR3, dynamat, RDO-194's, new drivers. psw 111 Pioneer 9040 BDP53fd 100 " screen Nakamichi HD projector, and Panasonic 65” plasma.
Haha, will do. Disneyjoe's post was the best explanation of the problem, it states the temp is xx when it's under or above that to start when it recovers during heating. I constantly have to fiddle with it otherwise it will overshoot by a big margin.polkaudio RT35 Bookshelves
To much night set back will cause problems with Adaptive Recovery. Does it only overtemp after night set back?Rec rm vm30 micro pro 3000 akai 2 channel. ht anthem MTX 5 channel anthem P2 statement anthem 325, 8 channel Martin Logan power amp for 4 ceiling ls900 2 and outdoor polks, 2 JL 110’s subs panasonic 65" plasma lsim 705’s , 706c, L200 and Control 4 garage rig monitor 10s crossovers by VR3, dynamat, RDO-194's, new drivers. psw 111 Pioneer 9040 BDP53fd 100 " screen Nakamichi HD projector, and Panasonic 65” plasma.
It overtemps pretty much after any set back, and I don't think a night temperature of 58-60 is unreasonable.polkaudio RT35 Bookshelves
No its not. Have you tried to set it back to Forced Air. The differance is in the anticipation of temperature, steam has a very high recovery rate, and seems like the stat can not react fast enough to shut down. Are your rads the older cast iron type?Rec rm vm30 micro pro 3000 akai 2 channel. ht anthem MTX 5 channel anthem P2 statement anthem 325, 8 channel Martin Logan power amp for 4 ceiling ls900 2 and outdoor polks, 2 JL 110’s subs panasonic 65" plasma lsim 705’s , 706c, L200 and Control 4 garage rig monitor 10s crossovers by VR3, dynamat, RDO-194's, new drivers. psw 111 Pioneer 9040 BDP53fd 100 " screen Nakamichi HD projector, and Panasonic 65” plasma.
It seems to be worst when I set it higher then 2f from where I like it. If more then that my AC / cooling needs to work harder and longer to bring it down. That is when it goes to 81f, where the its only 80f in the house and needs to go 79f.
My AC set is this.
3am -7am 78f
7am - 5pm 80f
5pm -11pm 79f
11pm - 3am 77f
I call that my 2 -3f setback, works best for me.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Haven't tried to set it back to Forced Air. It has always been set to Steam.
The radiators are the older cast iron type built after WWII. From the late 40's I would imagine.polkaudio RT35 Bookshelves
What s the day time temp?Rec rm vm30 micro pro 3000 akai 2 channel. ht anthem MTX 5 channel anthem P2 statement anthem 325, 8 channel Martin Logan power amp for 4 ceiling ls900 2 and outdoor polks, 2 JL 110’s subs panasonic 65" plasma lsim 705’s , 706c, L200 and Control 4 garage rig monitor 10s crossovers by VR3, dynamat, RDO-194's, new drivers. psw 111 Pioneer 9040 BDP53fd 100 " screen Nakamichi HD projector, and Panasonic 65” plasma.
67 F.
So you are saying steam has a fast recovery time? I always thought Forced Air (like those in central AC/heating systems with duct work) were faster at heating the room, I may be mistaken though...polkaudio RT35 Bookshelves
I was comparing to the same system on water. If no other settings have been changed and all is set to as before and worked ok. The stat has lost its ability to anticipate temp. 7 to 9 degree set back on slow recovery system is very large and should be rethought. 5 max.Rec rm vm30 micro pro 3000 akai 2 channel. ht anthem MTX 5 channel anthem P2 statement anthem 325, 8 channel Martin Logan power amp for 4 ceiling ls900 2 and outdoor polks, 2 JL 110’s subs panasonic 65" plasma lsim 705’s , 706c, L200 and Control 4 garage rig monitor 10s crossovers by VR3, dynamat, RDO-194's, new drivers. psw 111 Pioneer 9040 BDP53fd 100 " screen Nakamichi HD projector, and Panasonic 65” plasma.
Thanks! So I should set the thermostat to Steam?
From what I understand, hot water is a "baseboard" type heating system that is low to the ground. We have radiators that are about 2 feet tall with an air valve on one side and a knob on the other. I mistakenly thought that turning the knob to the full closed direction will eliminate a room like a "zone", but that's not what happened. I've also never touched the air valves either.
These things hiss, knock, and bang in the morning like the old houses in NYC.polkaudio RT35 Bookshelves
Yes to steam or a high mass setting which is for the cast iron rads. What are all the choices?Rec rm vm30 micro pro 3000 akai 2 channel. ht anthem MTX 5 channel anthem P2 statement anthem 325, 8 channel Martin Logan power amp for 4 ceiling ls900 2 and outdoor polks, 2 JL 110’s subs panasonic 65" plasma lsim 705’s , 706c, L200 and Control 4 garage rig monitor 10s crossovers by VR3, dynamat, RDO-194's, new drivers. psw 111 Pioneer 9040 BDP53fd 100 " screen Nakamichi HD projector, and Panasonic 65” plasma.
1. Gravity
2. Steam
3. Hot Water
4. Forced Airpolkaudio RT35 Bookshelves
Now I'm confused. The paperwork for this house says we have "Hot Water" but I think that is incorrect.
There's one pipe going into the radiator, a black knob on the left, and this thing on the right:
Edit: Sorry for the blurred picture but this is a steam system right?polkaudio RT35 Bookshelves
Steam, and try no large set back for a week with adapt recov on. Large setbacks do not save on slow recovery systems. 3 to 5 degrees max.Rec rm vm30 micro pro 3000 akai 2 channel. ht anthem MTX 5 channel anthem P2 statement anthem 325, 8 channel Martin Logan power amp for 4 ceiling ls900 2 and outdoor polks, 2 JL 110’s subs panasonic 65" plasma lsim 705’s , 706c, L200 and Control 4 garage rig monitor 10s crossovers by VR3, dynamat, RDO-194's, new drivers. psw 111 Pioneer 9040 BDP53fd 100 " screen Nakamichi HD projector, and Panasonic 65” plasma.
Can u take a pic if the boiler and surrounding pipingRec rm vm30 micro pro 3000 akai 2 channel. ht anthem MTX 5 channel anthem P2 statement anthem 325, 8 channel Martin Logan power amp for 4 ceiling ls900 2 and outdoor polks, 2 JL 110’s subs panasonic 65" plasma lsim 705’s , 706c, L200 and Control 4 garage rig monitor 10s crossovers by VR3, dynamat, RDO-194's, new drivers. psw 111 Pioneer 9040 BDP53fd 100 " screen Nakamichi HD projector, and Panasonic 65” plasma.
of the boilerRec rm vm30 micro pro 3000 akai 2 channel. ht anthem MTX 5 channel anthem P2 statement anthem 325, 8 channel Martin Logan power amp for 4 ceiling ls900 2 and outdoor polks, 2 JL 110’s subs panasonic 65" plasma lsim 705’s , 706c, L200 and Control 4 garage rig monitor 10s crossovers by VR3, dynamat, RDO-194's, new drivers. psw 111 Pioneer 9040 BDP53fd 100 " screen Nakamichi HD projector, and Panasonic 65” plasma.
Yes, here goes:polkaudio RT35 Bookshelves
