RTi12 with CsiA4 anybody else using this
Nerd
Nerd Posts: 68
edited December 2011 in Speakers
I bought the Csi A4 to go with my RTi 12s, looks like its working well, but I don't know the difference between this and the CSi a6,
will I get significant sound difference with Csi A6 or should I keep with the Csi A4's
Running it through Onkyo SR806
Polk RTi12
Polk Csi A4
Polk FxiA6
Outlaw LFM-1 EX
Onkyo TX SR806
Adcom GFA 555 MkII
LG 55" 3D 55LW6500
LG Blue ray BD670
Post edited by Nerd on
  • larry777
    larry777 Posts: 480
    I would go with the CSiA6 for those size towers. I have the RTi10's and my CSiA6 is a perfect fit. I did research on this site before buying this center speaker and the stronger opinion was in favour of the CSiA6 over the CSiA4. The CSiA6 is much bigger than the 4....but if you have the room definately go for the 6. The CSiA6 will give you a fuller more open sound, with awsome clarity.
    Home Theatre.............
    Pioneer SC-35
    Polk RTi10's Fronts
    Polk CSiA6 Center
    RTi4 Surrounds
    SVS PB-12 Sub
    2 Channel.............................
    Yaqin MC-100B
    Energy RC-70 Speakers
    Arcam CD-192 Disc Player
    Van Den Hul Interconnects
    Toolfan66 Posts: 17,995
    Or find a CSi5
  • Nerd
    Nerd Posts: 68
    Thanks for the advice.
    I checked the size and I will have to make some arrangements to put it where the Csi A4 is now. I bought the CSi A4 because it fit exactly on the stand in fornt of the TV.
    I will put it up for sale on CL or here and see if anyone wants it, they are brand new.
    Polk RTi12
    Polk Csi A4
    Polk FxiA6
    Outlaw LFM-1 EX
    Onkyo TX SR806
    Adcom GFA 555 MkII
    LG 55" 3D 55LW6500
    LG Blue ray BD670
  • Nerd
    Nerd Posts: 68
    Well, I can;t make sale here yet, have to cross 100 posts or something like that.
    I will try CL then, otherwise will hang on to Csi A4 a bit longer.
    Polk RTi12
    Polk Csi A4
    Polk FxiA6
    Outlaw LFM-1 EX
    Onkyo TX SR806
    Adcom GFA 555 MkII
    LG 55" 3D 55LW6500
    LG Blue ray BD670
  • Lego1
    Lego1 Posts: 62
    If it's brand new, can't you just return it? I would get the CSi5. Save some money by buying it over the CSIA6. It's basically the same thing. Since the voices and much of the audio comes through the center channel, I would buy the best you can.
  • Sherardp
    Sherardp Posts: 8,038
    Alot of forum members reported a huge difference over the larger center. I started out with the CSi5 and will tell you it was miles ahead of my old Yamaha center. It was so good, I looked at it in shock while it was performing. If you have the space go for the larger center.
