Need a new desktop
jayman_1975
It seems that just today my desktop pc has died and I am in need of a new one fairly quickly. I plan on spending only $500 and do not need a bunch of frills. It is mostly just for my son to do homework and mess around on you tube and occasionally I manage pictures and music on it.
Could I get a heads up on a smokin deal if someone has seen any?
Onkyo TX NR 5008 modified by The Upgrade Company
Oppo BDP 93 modified by The Upgrade Company
Arcam CD37
Monitor Audio Gold GS 60
Revolver Audio Music 5 towers.(surround)
Vandersteen V2W
Arcam CD37
Vandersteen V2W
Post edited by jayman_1975 on
Long ago i would say to build but its pretty cost effective to just buy a Dell. If I was buying a new PC, I'd probably buy a Dell unit.
Try the Dell outlet website and their auction site.DKG999
Music System: Magnepan 1.6QR, SVS SB12+, ARC pre, Parasound HCA1500 vertically bi-amped, Jolida CDP, Pro-Ject RM5.1SE TT, Pro-Ject TubeBox SE phono pre, SBT, PS Audio DLIII DAC -
Got a Lenovo for 429.00 at Best Buy not too long ago. It's been great so far. 4 GB memory, 1 TB Hard Drive.
I prefer Lenovo or HP. Regardless of what brand you're after, I recommend checking http://www.dealnews.com or http://www.techbargains.com or http://shopping.google.com to find the best bargains.
Using Google Shopping, I searched for a desktop PC with a minimum 2.8GHz Intel Core i5 processor and a minimum 4GB RAM for under $500, and it looks like this is the deal to beat:
http://www.amazon.com/E20-4222-Tower-Core-Sdram/dp/B0038GZCZ6
Monster AVL-300, HTS-2500 MKII -
Emachine, maybe a lenovo, sony, build your own?HT setup
Panasonic 50" TH-50PZ80U
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
MIT Exp 3 Speaker Wire
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
63 inch Samsung PN63C800YF
Polk Surroundbar 3000
Samsung BD-C7900 -
FWIW I would avoid eMachines. They are definitely cheap but they are not a good deal, as in their case you are getting exactly what you are paying for, not more. Back when I used to still work on residential computers they were my number one worst offender when it came to needing hardware repairs. Cheaply made power supply + a cheaply made motherboard = a computer with a very short life.
Sony does not make desktop computers any more, only all-in-ones which are not within the OP's budget.
I would say Dell or HP. Def stay away from Emachines, those things are terrible IMHO. Dell outlet should have great deals, go for Win 7 and at least 4gb ram. The standard Dell 8300 is just 100 over your budget but will handle everything you throw at it, includes an i5 processor as well.
http://www.dell.com/us/p/xps-8300/fs
or the Inspirion for 499.00
http://www.dell.com/us/p/inspiron-620/fsShoot the jumper.....................BALLIN.............!!!!!
The Lenovo I linked to above has a 3.2GHz Intel Core i5 CPU for $500. Still the deal to beat IMO.
Another vote AGAINST emachines. Mine lasted 1 year and 10 days, just past the warranty.I refuse to argue with idiots, because people can't tell the DIFFERENCE!
Thanks for the advice guys. I picked up an Acer unit locally for pretty cheap. I realize cheap is what I got too but in reality I only need it to last for a few years till my boy is gone from home and then I'll be buying a Mac. Thanks again.
Ps. I decided to go local for the convenience of warranty issues.Onkyo TX NR 5008 modified by The Upgrade Company
Arcam CD37
Vandersteen V2W -
Acer is cheap, but then again they haven't really appeared on my radar as being a problem brand either. There's certainly enough of them out there that I believe they would have if they were, for whatever that's worth.
