Listening in the dark
I-SIG
Is it me, or does the sound somehow come alive when you listen in the dark? Closing your eyes doesn't bring it t the same level.
I think it has somehting to concentration. I feel freer to listen, rather than concentraiting on keeping my eyes closed or whatever.
Wes
(I put this hear (pun intended) for the more critcal listening that tends to get done on our big two-channel rigs.)
Wes
Link: http://polkarmy.com/forums
Panasonic TH-42PHD8UK 42" HDTV | Polk Audio SDA-SRS's (w/RDO's & Vampire Posts) + SVS PC+ 25-31 | AudioQuest Granite (mids) + BWA Silver (highs) | Cary Audio CAD-200 | Signal Cable Silver Resolution XLR's | Wyred 4 Sound STP/SE Pre | Signal Cable Silver Resolution XLR's | Cambridge Audio azur 840C--Wadia 170i + iPod jammed w/ lossless audio--Oppo 970 | Pure|AV PF31d
Post edited by I-SIG on
The reason why it is easier to listen to the dark, is you arnt glaring at these black boxes moving air...
It seems you can sit back and concentrate past examining things!
I agree with you, when I can I turn off the lights and jam so I can actually enjoy the music!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
CLOSE YOUR EYES
AND I'LL KISS YOU...................... -
Agreed, the concentration bit pretty much hits the nail on the head. Most important for me though is dead silence, which, in a house of 6 isn't that easy to accomplish most of the time. Not to mention in the dark with 5 sleeping, it's a good way to make the wife have a bad hair day when she gets up.......:eek:Remember, when you're running from something, you're running to something...-me
I agree. Incondescent light also produce some sort of noise that I can hear.
Maurice -
I'm afraid of the dark.
George Grand (of the Jersey Grands) -
It's OK, George... bike zappa is several states away...
I-sig,
Same here. We've had discussions here on why. Mostly boils down to cleaner power at night vs. some kind of psycho-acoustic phenom.
Either way doesn't matter. It's nice to just enjoy...More later,
Tour...
Vox Copuli
Yep, lights very low or off for serious listening. Something about using hearing as opposed to seeing for me. Sensory perception changes.
Hell, I cant really say but its all good. -
I know the properties of light and sound are such that one should not interfere with the other...but I wonder anyway if there's somethere for an explanation?
If you are listening to a performance you want to hear the soundstage and depth along with all the other stuff in the recording. It is really tough to imagine a vocalist standing in front of you or to feel like you are somewhere you aren't when visual clues tell you otherwise. I start to loose concentration if it is too dark though.
madmax
Start snoozin', eh?
WesLink: http://polkarmy.com/forums
Panasonic TH-42PHD8UK 42" HDTV | Polk Audio SDA-SRS's (w/RDO's & Vampire Posts) + SVS PC+ 25-31 | AudioQuest Granite (mids) + BWA Silver (highs) | Cary Audio CAD-200 | Signal Cable Silver Resolution XLR's | Wyred 4 Sound STP/SE Pre | Signal Cable Silver Resolution XLR's | Cambridge Audio azur 840C--Wadia 170i + iPod jammed w/ lossless audio--Oppo 970 | Pure|AV PF31d -
I use to listen in the dark, but my right channel would go out so I quit.Dodd - Battery Preamp
ADS 1230 - Polk SDA 2B
Crown K1 - Subwoofer amp
Outlaw ICBM - crossover
Beringher BFD - sub eq
"I've always been mad, I know I've been mad, like the most of us have...very hard to explain why you're mad, even if you're not mad..." -
The right woke up last night! WooHoo!
whistling in the dark....
Dancing in the dark???More later,
Tour...
Vox Copuli
Originally posted by Polkmaniac
whistling in the dark.... -
I never understood the facination with 2 channel audio until I turned off the lights and hit play on Extreme Pornografitti.
Should also remove all clothing to maximize effect on body. And get rid of glasses to minimize room reflections.
Seriously, I listen in the dark as well....late at nite and at low volume. -
Originally posted by Danny Tse
....late at nite and at low volume.More later,
Tour...
Vox Copuli
No,no,no,...
It has nothing to do with distortion. Your must be completely naked.
