Buffing out scuffs and light scratches LSI15
edited December 2011 in Speakers
Has anyone ever tried to buff out scuffs and light scratches in the LSI series? Wondering if it can be done, and how to do it...
Post edited by Brasiliaflyer on
Welcome!
    Flitz polish - small dab on a damp soft cloth, work it around, then buff w/ a dry soft cloth
    body grinder:eek:
    Just kidding
    3M polishing products are excellent.
    I wet sanded mine with excellent results, wish I took pics cause you would be able to see a huge difference
    Samsung pn64f8500
    Sonus faber venere 2.5
    Sf venere center
    Oppo 105d
    Squeezebox touch
    Parasound hca1500a
    Apc power filter
    Audioquest cables asst
    Polk rtia3 SB
    Polk fxia6 sl,sr
    Dual hsu vtf3 mk3
    What part of the speaker?
    AVR-Onkyo TX-NR808
    Front amp-Adcom GFA 555>Polk Audio LSi9's(Vr3 Castle Mods)
    Center amp-Adcom GFA 5400>Polk Audio LSi9 bi-wired(Vr3 Castle Mod)
    Surrounds-Polk Audio F/X500's<Onkyo TX-NR808
    Sub-Velodyne SPL-1000R
    Is that the plastic polish ? I have a pair of these on the way that may require some attention. Thanks. :cool:
    3M's stuff is very good, as well as Macquiars Scratch-x. Start with light pressure.
    For little nicks & scratches, I have had good luck with a bit of walnut (the meat NOT the shell) smashed onto the scratch then rubbed to get the nut oil onto the wood; pick off the excess nut meat and buff with a soft cloth.
    For stuff like water marks I use Howard Restor-A-Finish followed by Howard Feed-N-Wax. Great products.
    Cheers, Jim
    A day without music is like a day without food.
    If it's like the top of the RTA15 which i believe is acrylic i used the 3 step NOVUS stuff and it worked great.
    I’M OFFENDED!!!!
Welcome!
Welcome!
