X-over help needed
heiney9
Looking at the schematic for the RT25i on the tweeter section they use a 1.0uF Film cap in parallel with an 8uF electrolytic. Shouldn't I be able to use a single 9uF Poly and jumper the second postion?
Post edited by heiney9 on
Yes, a single 9uf would be fine, but do not install a jumper."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
What Face said^^ Not what SDA1C said.
The Mystery of the Vanishing Post
Thought SDA 1C took his ball and went home?
Thanks Face, I wasn't sure if I had to jumper the open position where C2 would be or not.
H9"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul!
