Optical Cable Splitters? Quality loss?
Trenchant
Trenchant Posts: 28
I have two stereo systems in my house. My main Polk setup in my room and a Bose system in my living room. My laptop serves as the audio source for my Polk stereo and I would like the signal to be duplicated and sent to the Bose stereo as well.
I am currently using a USB sound card with an optical cable connected to my Polk Stereo. Would using an optical splitter like the one below reduce signal quality?
http://www.monoprice.com/products/product.asp?c_id=104&cp_id=10423&cs_id=1042301&p_id=966&seq=1&format=2
Upgrading my receiver to one that includes multiple zones isn't a priority right now. This feature will rarely be used but it would be nice to have if it can be done for $25.
Towers: Monitor 70's
Center: CS2
Rears: Monitor 30's
Sub: MicroPro 3000
Receiver: Pioneer VSX-D409
Screen: Samsung 42" 720p
All in a 12x12 bedroom...
Post edited by Trenchant on
  • Fongolio
    Fongolio Posts: 3,516
    edited December 2011
    As long as both sides still see the light (so to speak) I don't see how it could degrade the signal as long as the lengths are within the normal operating range for optical. It's cheap to find out.
    SDA-1C (full mods)
    Carver TFM-55
    NAD 1130 Pre-amp
    The Clamp
    Nakamichi CR7 Cassette Deck
    Cambridge Audio DACmagic Plus
    ADC Soundshaper 3 EQ
    Ben's IC's
    Nitty Gritty 1.5FI RCM
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    My thinking is that a splitter would reduce signal by -3db, which is half the signal it started with. But understand a -3db in optical terms shouldn't bother the signal at all on the receiving end. Length of cable could reduce signal also, so length of cable is important factor also.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • Syndil
    Syndil Posts: 1,582
    dB does not apply to light or to 1s and 0s. But if for whatever reason the signal does become unreliable, you would need to implement an optical digital repeater somewhere along your cable run.
  • disneyjoe7
    If the light is too low then yes db is God! it's dead. Won't work.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • Rivrrat
    Rivrrat Posts: 2,101
    Syndil wrote: »
    In the telcom world light loss is measured in db's ( where I believe I remember DisneyJoe works, as do I).
    All anyone would want to know about loss if you follow the links on the page. :lol:
    http://en.wikipedia.org/wiki/Insertion_loss
    In telecommunications, insertion loss is the loss of signal power resulting from the insertion of a device in a transmission line or optical fiber and is usually expressed in decibels (dB).;
    The splitter would be the device
    There will be loss in that connection, as there's loss in any optical connection fusion or mechanical, but I doubt if you're just using one splitter and the run is short, it'll ever be a problem.
    My equipment sig felt inadequate and deleted itself.
  • dorokusai
    dorokusai Posts: 25,576
    I'm also in Telecom(19yrs) Rivrrat and you're correct. I work with fiber from time to time. My life is 100% db related, whether its coaxial or fiber optic.
  • disneyjoe7
    Rivrrat wrote: »
    I believe Joe Q public doesn't know or care about db loss when it comes to optical cables. It's marketing I'm sure.
    Work in Teleco Inside or Outside? I work as an Electronic Tech inside CO 5E switch and everything else.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • Rivrrat
    disneyjoe7 wrote: »
    I doubt Joe Q public cares either, but when they make an incorrect statement about db's not relating to light transmission........
    I work outside as an equipment installer and power tech. If it needs to go in a cev, rt, or customer premise, I put it in and make sure it stays powered. Like most techs, I've done a bit of everything through the years.
    Lots of dsl to the neighborhood right now.
  • steveinaz
    steveinaz Posts: 19,546
    Here's the switch I've used in the past (Inday D4X-R), it does the splitting "electronically"
    http://www.inday.com/da4x/da4x.htm
