Review - Claritycap ESA as coupling caps
quadzilla
quadzilla Posts: 1,543
edited December 2011 in DIY, Mods & Tweaks
A couple of days ago, I swapped out the Sonicap Gen I .22 uf coupling caps in my Aural Thrills KT88 monoblocks for Clarity ESA .22 uf caps. The cost was a only 30 bucks, so I figured I'd give it a shot and see if it was worth the hassle. I think yes... yes it was. Now, on to the review:
I got a chance to sit down and do some listening to the new caps in my amps tonight. I'll try to point out the good and the bad, but I'm sure the sound will change over the next few weeks quite a bit, as they've got less than 5 hours on them now. When they get to about 100, I will probably post a followup review. That said, here we go...
The first thing I noticed is that these are much more neutral sounding at this point than the Sonicaps. Just swapping out the sonicaps for the claritys as coupling caps in my amps brings out a lot more balanced sound in my rig. I run a CJ tube pre and aural thrills tube monoblock amps, so the system tends towards warm any way, and with the sonicaps as the coupling caps running my TLed CRS+s, I felt the system was far too warm, to the point that other parts of the sound were getting lost. And with the stock 2.3 TLs, I still felt the system was still a bit too warm and the vocals too forward when using the sonicaps as the coupling caps. Now it's more neutral while having more extension at the top and bottom, as well as more detail and nuance in the sound. And some grain that I didn't realize was there until it wasn't any more is gone as well, leaving a smoother sound. And an absolutely black background. I expect the new caps may warm up a bit and smooth out even more over the weeks, but we'll have to see about that. This is my first go around with these, so it's an adventure. And if they do warm up just a touch, I think the balance will be just perfect. That's not to say they even approach analytical at this point, but just another pinch of warmth would be very acceptable. And if they keep the balance they have now, that's also just fine by me. I don't see myself feeling disappointed with this mod either way.
Something else I'm hearing is more textured, detailed bass. For example, the bass was a bit soft before the swap to the point that the kick drum could get kind of lost in the bass lines at times. Now the strike of the pedal head is quite distinct, as is the vibration of the drum head, even through fairly busy bass lines.
Detail and clarity are enhanced across the spectrum. The sound stage is more focused as well, while growing in width, but moving back a bit in the center. Vocals always used to come from a space that seemed to be about 3-3.5 ft wide and too far forward, more-or-less in the middle (front to back) of the room. Now it sounds more like a person standing there singing in front of a band. No depth seems to have been lost though. Bass and drums tend to come from a space about 8-10 ft behind the singer, while other instruments range from about 3-4 ft in front, to 4-5 ft behind the speakers. The singer generally seems to be either right between the speakers, or 2-3 ft in front of them. The sound stage itself seems to occupy a space of about 16-18 ft wide. Which is cool, since the room is only 15 ft wide.
Those are the main differences I hear. Of course, if you like a forward sound stage, which I'm sure many people do, a very warm sound and a bit larger than life instruments/vocals, then these caps don't seem to be what you want. The only other downside is that I wouldn't complain if the vocals moved back forward maybe a foot, after having fallen back about 6 ft. But still, I prefer the vocals to come from within the same space as the rest of the sound, rather than sounding like the singer is standing on the end of a runway.
So I have to thank Ben for having posted the original cap shootout thread with his compliments of the Clarity MR series, and all the people that have contributed to the various threads I started while planning The Big Upgrade over the last few months. I appreciate everyone's time and input while I decided on which way to go.
Turntable: Empire 208
Arm: Rega 300
Cart: Shelter 501 III
Phono Pre: dsachs consulting
Digital: Marantz SACD 30n
Pre: Conrad Johnson ET3 SE
Post edited by quadzilla on
    VR3 Posts: 29,441
    Clarity Cap FTW!! :)
    I thoroughly like their entire line up!
  • headrott
    headrott Posts: 5,496
    Thanks for the review. Interesting comments. I have read others say that the ESA caps have a warmer sound to them (compared to Sonicaps). That is (I'm sure) after they have burned in though. Probably, the soundstage will balance out more as well as they burn in. Please keep us updated.
    Greg
    VR3 Posts: 29,441
    I have found the ESA to take about 200 hours to burn in completely, YMMV
  • quadzilla
    Thanks for the feedback. Yeah, I do expect the sound to change. And, headrott, your comment makes me wonder if maybe what I'm perceiving as "more neutral" is the vocals not being quite as forward in the mix now. I've got some recordings where it literally sounded like the singer was leaning down and signing right in my face, and I sit about 14 ft back from the speakers. The detail and texture increases, especially at the top and bottom end is unmistakable though. What surprised me the most was that, in replacing a well burned in set of sonicaps with a brand new esa set, it immediately sounded a lot better, and not in subtle ways. My expectation had been that, at least initially, it would sound a bit worse, or if I got lucky, about the same. I really didn't expect them to be *that* much better right away.
    Arm: Rega 300
  • quadzilla
    Got about 10-15 hours on these now. It's a bit clearer, but the sound stage shrunk front-to-back a bit while growing to the sides about another foot. I also figured out why I perceive these as more neutral. The sonicaps had a hump around 70 Hz that's gone now. That, coupled with the more open highs makes these sounds more neutral to my ear.
    Arm: Rega 300
  • headrott
    Thanks for the further review. I like the idea that there are more open highs with the Clarity Caps. Please keep us informed on further enhancements, etc.
    Greg
    heiney9 Posts: 25,445
    I am curious, how do you know the Sonicaps had a "hump" at around 70 Hz?
  • agfrost
    agfrost Posts: 2,469
    We'll do a comparo, Brock, when I finish up my DAC with my Sonicaps. Tune your ears for 70 Hz!
    Jay
    Hey Jay,
    How's that project coming? I apologize I haven't gotten back to you about what left over caps I might have. I keep forgetting to look. I am getting ready to order some Clarity caps for my newly aquired Polk RT25i's to upgrade the x-overs.
  • agfrost
    Cool. I'm amassing parts; no hurry. Sorry for the thread derail here.
    Clarity!
    Jay
  • Face
    Face Posts: 14,340
    quadzilla wrote: »
    I don't believe he's tried MR's, that was someone else.
  • george daniel
    george daniel Posts: 12,096
    I put the MR's in my Belles 20a.Big A$$ caps.
