SDA 1.2tl's with Dueland Resistors
Yeah, I just bought 10 of those suckers. So yes, I paid 500 bucks for resistors for my xover upgrade.Turntable: Empire 208
Arm: Rega 300
Cart: Shelter 501 III
Phono Pre: dsachs consulting
Digital: Marantz SACD 30n
Pre: Conrad Johnson ET3 SE
Speakers: SDA 2.3TL, heavily modified -
Why did you need 10?
Greg
"Have A Little Faith! And Everything You'll Face, Will Jump From Out Right On Into Place! Yeah! Take A Little Time! And Everything You'll Find, Will Move From Gloom Right On Into Shine!"- Arthur Lee -
Larry, is there a reason why you used Mills for the .5 resistor in place of the poly? Is it overkill to use the Dueland there? I would think it makes a difference anywhere in the signal path?Good music, a good source, and good power can make SDA's sing. Tubes make them dance.
