Harmony Remote Batteries
Sherardp
Guys,
Just wanted to post this since so many of us use Harmony Remotes. Check and inspect the batteries in these things. I just opened mine up to inspect the battery and only to find it swollen and cracking. Here are some pics? I've had this for about yr and half so I'll be checking mine on a regular basis now.
Post edited by Sherardp on
Could you have a defective charger? Mine remote is like 6yrs old and my battery doesn't look nothing like that.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
I wouldn't put that back in my remote.
I do not own one but my sister does and she DID have the battery swelling issue. Now if this is a design flaw then put it in the instuctions that after the initial charge you do not need it to be in the carraige for quite some time. Then you have the same problem of misplacing one remote instead of 7 as w/ me.I'm still not a convert yet because my systems are all interelated and I'm not sure it can do what I need it to do. I did call Logitec and I got to tell you the guy was not all that reassurring.2chl- Adcom GFA- 555-Onkyo P-3150v pre/amp- JVC-QL-A200 tt- Denon 1940 ci cdp- Adcom GFS-6 -Modded '87 SDA 2Bs - Dynamat Ext.- BH-5- X-Overs VR-3, RDO-194 tweeters, Larry's Rings, Speakon/Neutrik I/C- Cherry stain tops Advent Maestros,Ohm model E
Well I just got off the phone with Harmony support and they would not replace the battery or the remote. They did offer me a 50% discount coupon for my troubles. I was able to order a replacement battery from Amazon. If you can't get the battery out then you maybe screwed as some have been. If your relative has this issue, have her contact Logitech ASAP @ 1-866-291-1505 for Harmony support.Shoot the jumper.....................BALLIN.............!!!!!
