Hk 990
mara5
Ok, first we need to know the full model number. Second, what are u using this with and for? What is the associated equipment, room size, music or movies, etc. Then perhaps folks will chime in.Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
That is the full model number. This is HKs new 2000+ dollar integrated amp, I believe it is a 150 watts x 2 and fairly well built. I have the companion CDP...the HD 990 which, at its price point, is pretty good. I cannot speak to the integrated because I have not heard that but the "reviews" have been favorable although I would add that I think 2000+ is a bit much for that unit feature wise!
I doubt they will sell many for 2000-2500. But if they had offered it in the 1200-1400 dollar range they may have had more "takers". They set their price point too high because there's a LOT of great gear available for $2500 or a bit more!
As stated that is the full model #. When purchased would be used with KEF xq40's. 2Ch. only room approx. 14x14 (open stairwell).
CNH it can be had for $1599. now -
Again I haven't heard this particular unit. But I'd probably consider biting if it were 1500 or less and I had the cash on hand which would put it in the NAD C375 and the Cambridge Audio Azur 840A price range--good company!
I like the HK sound (in general) and think it would probably pair well with KEFs!
Again - if you don't mind buying used:
Nice price for the Cambridge 840A- seller has good rating (no affiliation):
http://www.audiogon.com/cgi-bin/cls.pl?intatran&1328532619&/Cambridge-Audio-840A-V1-Silver
Another plug for the MF 3.2:
http://www.audiogon.com/cgi-bin/cls.pl?intatran&1328146825&/Musical-Fidelity-A3.2
With either, you'd have plenty of coin left over if your budget is $1500 to buy some good quality interconnects and music to enjoy the setup.
Why is that HK model so expensive? What makes it sooooo much better than the HK-3490?
Look at the insides:
http://www.harmankardon.com/resources//Brands/HarmanKardon/Products/ProductImages/en-US/HK%20990/HK%20990_IMG5_800X600.GIF
That's a different architecture and 20 more lbs of weight with DUAL toroidal Transformers, etc.
Reported
Monster AVL-300, HTS-2500 MKII -
If I were to fall in love,It would have to be with youYour eyes,
Sacramento Escort your smile,The way you laugh,The things you say and do
Take me to the places, Sacramento Escorts My heart never knew
So, if I were to fall in love,It would have to be with you. Sacramento Asian Escort
Ed Walter,Forgive me for needing you in my life;
Forgive me for enjoying the beauty of your body and soul; Sacramento Asian Escorts
Forgive me for wanting to be with you when I grow old
That's got to be the best spam ever...at least the most poetic.Things work out best for those who make the best of the way things work out.-John Wooden
