Setting it all up. (Amp) question.
Phasewolf
Phasewolf Posts: 514
edited December 2011 in Electronics
My current setup for HT is using a Pioneer receiver too drive my sda's which is not a good place too go. So I have a nice Luxman coming that I will use too drive the sda's. Now I am going to use the Pioneer pre outs too hookup into the amp but what I want too know is if I setup the receiver so at say 0db all channels are outputting the same spl will the channel lever track correctly right at say -20bdthe on the receiver or not.
Absolute corruption empowers absolutely.
Lg 55LW5600 TV
Onkyo PR-SC 5508
Legacy Audio Focus SE
Legacy Audio Silverscreen HD center
Polk F/X500i Rears
Parasound HCA-3500
Sunfire Grand Cinema
Behringer iNUKE NU6000DSP
Pair of CraigSUB SS-18.1
Post edited by Phasewolf on
  • Marty913
    Marty913 Posts: 760
    If I understand what you're asking, the pre-outs will reflect the same relative output gain as the internal amps would. Having said that, the input voltage sensitivity level of Luxman (unknown to me) will require that you reset all levels after hooking everything up. Switching amps or introducing a new amp requires redoing the levels.
    Sony 60'' SXRD 1080p
    Amp = Carver AV-705THX 5-Channel
    Processor = NAD T747
    Panasonic BD35 Blu-Ray
    Main = SDA-1C Studio with RD0s, spikes, XO rebuild, rings, I/C upgrade
    Center=Polk CS10, Surround = Athena Dipoles, Sub= Boston 12HO
    Music/Video Streaming = Netgear NEO550
    TT = Audio Technica
  • Phasewolf
    I knew I would have too setup the levels again on the receiver sense I would be using a separate amp and not the internal amp in the Pioneer. I really just wanted too make sure that once I did that the volume knob on the receiver would track correctly accost all channels where ever I set it.
    Lg 55LW5600 TV
    Onkyo PR-SC 5508
    Polk F/X500i Rears
    Parasound HCA-3500
  • Marty913
    Marty913 Posts: 760
    Once the levels are reset (+/- whatever dB), the pre-out output gain will respond to the volume knob just like the internal amp did. Does that make sense? Not sue I answered the question completely.
    TT = Audio Technica
  • Phasewolf
    Thanks for the help.
    Lg 55LW5600 TV
    Onkyo PR-SC 5508
    Polk F/X500i Rears
    Parasound HCA-3500
