Got me a HCA-2200
I-SIG
I-SIG Posts: 2,243
edited April 2004 in Electronics
Well, the searching and waiting is over.
I finally got my Parasound HCA-2200. I haven't had a good chance to listen to it, but I think I'm gonna like it. It is currently playing on repeat with a fan blowing to help get everything burned back in.
I'll give a better report this weekend sometime.
Wes
Link: http://polkarmy.com/forums
Sony 75" Bravia 4K | Polk Audio SDA-SRS's (w/RDO's & Vampire Posts) + SVS PC+ 25-31 | AudioQuest Granite (mids) + BWA Silver (highs) | Cary Audio CAD-200 | Signal Cable Silver Resolution XLR's | Rotel Michi P5 | Signal Cable Silver Resolution XLR's | Cambridge Audio azur 840C--Wadia 170i + iPod jammed w/ lossless audio--Oppo 970 | Pure|AV PF31d
Post edited by I-SIG on
  • Ceruleance
    Ceruleance Posts: 991
    edited April 2004
    welcome to the club
  • dorokusai
    dorokusai Posts: 25,576
    edited April 2004
    Wes - Nice to hear about your new gear, am looking forward to hearing your thoughts. It is a solid performer, the MKII was the first piece that began the John Curl dynasty at Parasound.
  • fireshoes
    fireshoes Posts: 3,167
    edited April 2004
    I need to get an amp. I heard cmy330go's LSi9's with Parasound Halo....holy crap!
  • organ
    organ Posts: 4,969
    edited April 2004
    Sweet. How many watts/ch is it? What speakers will they be powering?
    Maurice
  • dorokusai
    edited April 2004
    Continuous Power Output - Stereo
    250 watts RMS x 2, 20 Hz-20 kHz, 8 ohms
    385 watts RMS x 2, 20 Hz-20 kHz, 4 ohms
    385 watts RMS x 2, 20 Hz-20 kHz, 2 ohm
    Continuous Power Output - Mono
    750 watts RMS, 20 Hz-20 kHz, 8 ohm
    1000 watts RMS, 20 Hz-20 kHz, 4 ohms
    Current Capacity
    50 amperes continuous
    90 amperes peak
    Slew Rate
    >135 V/µsecond
    Frequency Response
    2 Hz-95 kHz, +0/-1.5 dB
    Total Harmonic Distortion
    < 0.05% at full power
    < 0.009% typical levels
    IM Distortion
    < 0.03%
    TIM
    Umneasureable
    Dynamic Headroom
    > 1.5dB
    lnterchannel Crosstalk
    > 84 dB at 1 kHz
    > 74 dB at 20 kHz
    Input Impedance
    100K ohms/RCA-unbalanced, 200K ohms/XLR-balanced
    S/N Ratio
    > 114 dB, input shorted, IHF A weighted
    Damping Factor
    > 1000 at 20 Hz
    Dimensions
    19" wide x 7" high x 15" deep
    Weight
    60 lbs. net
    AC Power Requirements
    1000 watts
  • I-SIG
    I-SIG Posts: 2,243
    edited April 2004
    Maurice
    Maurice,
    Mark took care of the amp info. Thanks. :)
    The HCA-2200 will be pushing a set of SDA-1C Studio's through some AQ CV-4. I have full CV-4 per terminal, so I have a decent size, quality pipe to push all those watts through!
    Wes
  • I-SIG
    I-SIG Posts: 2,243
    edited April 2004
    Well, I think Ihave done enough inital listening to go ahead and make some remarks.
    While, I have never doubted that the source makes a difference, but I was able to really notice this fact in my initial source selection to get the amp burned in again.
    I started using about a 10-12 year old Kenwood changer mainly because it would just keep repeating all the CD's. When I sat down to listen a little, I thought I had made a major mistake on the amp.
    So yesterday, I swapped back to my Onkyo DVD changer. HUGE difference. It was like I removed a pillow that was stuck in front of the SDA's! A decent soundstage returned and my highs came back as well.
    Anyway, now that I'm back to the source I'm comfy with, I have to say that Ithink I really like this amp a lot. It seems to be exerting little effort, even at 95+ dB's.
    The bass is great. Fuller, clearer, more precise and most importantly, a bit more "growl." I think it is able to get the SDA's to reach down at least another half-octave with good response. It also seems that as the volume increases or when there are more things happening in the bass region, it give more due diligence to everything that is going on. The Carver M1.0-t seemed like it would just focus more on the simple bass tones, and not give the kick drum or other things enough juice to keep them blended with the rest of the bass.
    Mids are definitely clearer and more precise. However, some things don't seem as forward as ther were with the Carver, which I think once I'm adjusted, will be a better staged sound. For example, the snare drum seems bit farther back from the singer. Vocals are where I noticed the margest improved, mainly in clarity and precision.
    The highs are improved over the Carver, but not the extent that mid and bass has improved. They seem to image better and are smoother, but I don't think the overall reproduction of the sound itself, is significantly better. Incrementally, for sure.
    I guess that is enough for now. One thing that I did notice that I think is worth mentioning is that in some CD's that are not the greatest quality, recording-wise (like Ten from Pearl Jam), seemed to be markedly clearer and fuller with better imaging. Maybe this can be explained by my lack of expectation from these CD's? :confused: Anyway...
    Wes
