Convention in rating speaker impedance
Serendipity
Never mind, figured it out...
polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
Front projection, 2 channel, car audio... life is good!
Post edited by Serendipity on
Never mind, I think the issue is with the receiver.
http://www.polkaudio.com/forums/showthread.php?126965-Why-do-the-new-Onkyo-TX-NRx09-receivers-sound-so-bad-for-music
Newer Onkyos = less current.polkaudio RT35 Bookshelves
Not that it helps... but the RTi A9's are a 8-ohm speaker that dip down to 4.5 ohms. I think this is standard with many speakers where the impedance will dip depending on frequencies?
Yes, it's normal. But if the speaker is rated at 8 Ohm nominal, then it's fine if the AVR/amp is also rated for 8 Ohm speakers.Turntable: Empire 208
Arm: Rega 300
Cart: Shelter 501 III
Phono Pre: dsachs consulting
Digital: Marantz SACD 30n
Pre: Conrad Johnson ET3 SE
