Do the Polk RTi70's hold up to todays standards??
Hello Polk community,
Newbie here. I have just started getting into home audio equipment. I'm trying to piece together a decent lower budget home entertainment system. I have an opportunity to pick up a pair of used RTi70 speakers for $200 from a local guy. I know there a bit old now and curious too how they hold up vs. some of the newer polk speakers. Like I was looking at the polk Tsi100's(Witch I know are smaller bookshelf speakers but new are around the same price). Do you think I'll be disappointed. I have read the reviews of the Rti70 from when they were first available almost 8 years ago. And the pro's seem to way outweigh the cons.
I'm going to be using these speakers to music and as part of a surround sound system. But mainly for music. I have just recently picked up a Denon AVR-1612 625 watt receiver, and a Polk psw110 sub, the sub I'm in love with. I'm also planning on picking up the Polk CS400 center channel also in the future
Do you think these RTi70 speakers are a good deal, and I should be able to get some good use out of them.
Thanks Guys,
James
Thanks Guys,
James
Post edited by JamesL on
Well I'm sure they sound fine compared to newer speakers but 200 sounds a little steep considering you can get brand new Rti8's from Fry's for 300 a pair or Monitor 60's from Newegg for 200 a pair. If you really like the old look of that line then go for it, it's definitely a good speaker. I just replaced the Rti100 but mine were 8 years old and still in perfect shape.
$200 is too high for those speakers. I sold mine for $180, and that was something like 5 or 6 years ago.
They're an OK speakers, but are the least favorite of that RT line for many people, probably myself included but I'm going strictly on memory here. I would look for an older or newer pair if you're going with the RT line. -
I absolutely hated the I70 - it was my last brand new set of Polks I ever purchased and ultimately turned me off of Polk's speakers for a LONG time. After that I switched brands.
I recommend looking elsewhere, particularly at the price - if you could get them for a hundy or a buck twenty five, maybe...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
My experience with the RTi70's was the exact opposite of the last poster's. They were my first Polks and I still have them in my HT system as rear's. I loved them from the start. I now have RTiA7's for fronts in the HT and Polk SDA1C's for two channel.
What the others have said is true. $200 is high for those speakers used. The pair with the CS400 center for $200 is more like it. Oh and by the way, welcome to Club Polk!!
KelvinSDA-1C (full mods)
Carver TFM-55
NAD 1130 Pre-amp
The Clamp
Nakamichi CR7 Cassette Deck
Cambridge Audio DACmagic Plus
ADC Soundshaper 3 EQ
Ben's IC's
Nitty Gritty 1.5FI RCM -
Thanks for the replies guys,
I went and ahead and purchased the speakers. Not for the asking price, so I think I did alright. They appeared well takin care of. I hooked them up as front L/R. I need to pick up new 16g wire lay it all out equally and buy some proper banana clips. Overall to my untrained ears, I feel like I got my monies worth, I'm happy with them. The have pretty good mids and the treble is nice, Paired with the subwoofer it fills the room nicely. I think I still need to fine tune the equialzer. But I'm still learning all the features of the reciever. Hopefully I can use them and grow into them a little bit as I learn more about the whole Home Audio thing. -
Good to hear you're happy with your purchase. In the end that's all that counts.SDA-1C (full mods)
Carver TFM-55
NAD 1130 Pre-amp
The Clamp
Ben's IC's
I'm running RTi70 mains in a matched 9.1 system. If you're like me, you'll find a bit of harshness at the very high end... but it can be tamed with careful equalization (or a quick run-through of Audyssey MultEQ). Happy listening, sir!Equipment list:
Onkyo TX-NR3010 9.2 AVR
Emotiva XPA-3 amp
Oppo BDP-93 Blu-ray player
Epson 8500UB 1080p projector
Elite Screens Sable 120" CineWhite screen -
I was fairly displeased with them. I'm glad I sold them and kept the RT55's. Not bad for the price paid, but there are better for the money.Main Surround -
Den - Rotel RSP-1068 / Threshold CAS-2 / Boston VR-M60 / BDP-05FD -
Nice speakers, but like others have said, try to get them cheaper than $200.
