Receiver for music only?
mara5
mara5 Posts: 54
edited November 2011 in Electronics
Is there such an animal? Need new receiver, music listening only. All receivers seem to be more designed for HT. Paying for a lot of extra's that won't be used. Room (LV) is about 14x14 with open stairway. Budget is $1500ish. Any recommendations? Don't mind paying, but would like some value.
Post edited by mara5 on
  • nguyendot
    nguyendot Posts: 3,594
    Find a two channel receiver...like a NAD. A lot of people use the HK 3490 as well. For your price? Most people go with an integrated amp.
    Main Surround -
    nooshinjohn Posts: 25,877
    Pioneer has a couple pretty good units in their Elite line...
    http://www.pioneerelectronics.com/PUSA/Home/Audio-Components/Hi-Fi+Audio
  • Syndil
    Syndil Posts: 1,582
    mara5 wrote: »
    Separates. With that kind of budget, no reason not to.
  • BlueFox
    BlueFox Posts: 15,251
    Yes, seperates is the path if you want to spend money. I just did a quick check on two-channel receivers, and Audio Advisor has either lower cost receivers, or they have built-in CD or DVD players.
    http://www.audioadvisor.com/products.asp?dept=100
  • Conradicles
    Conradicles Posts: 6,324
    NAD gets my vote.
  • nguyendot
    Some people want simplicity....but I agree, separates is the way to go. Reference CD player, pre, amp.
    Main Surround -
    mhardy6647 Posts: 34,913
    Does the OP really want a receiver (i.e., pre-amp, power amp, and [FM] tuner in one box)? I am guessing "no", so I will suggest that a good performance value option was and still is an integrated amplifier. Still some nice ones available at reasonable price points from NAD, Marantz, Yamaha, Cambridge Audio, etc. ... or there's always vintage :-)
  • Erik Tracy
    Erik Tracy Posts: 4,673
    When you say 'receiver' - do you mean that you need a built in FM section for 'radio'?
    And do you also mean that you want multi-channel as well for a 5.1 'music only' setup?
    Or is a 2-channel component for music only what you are looking for?
  • pearsall001
    pearsall001 Posts: 5,222
    Check this one out...it's always has received stellar reviews...http://www.outlawaudio.com/products/rr2150.html. If that doesn't float your boat then an integrated is the way to go. A HT receiver would give you too many bells & whistles you would never use. The suggestions so far on integrated amps is solid. Do some homework on all suggestions. Good luck! Bye the way...what speakers did you wind up with?
  • dkg999
    dkg999 Posts: 5,647
    With a $1500 budget I would go with a really good integrated amp and then let the tuner battle sort itself out. I would probably connect up a SqueezeBox Touch that lets you stream radio stations from the internet.
    DKG999
    One of the best receivers in that sub-1000 dollar range is the Outlaw Phil lists above. Otherwise with a budget like 1500 you could get some really nice stuff from NAD or Cambridge Audio. A decent integrated and matching tuner. That would serve you well!
    What speakers are you going to drive with that?
    cnh
  • dudeinaroom
    dudeinaroom Posts: 3,609
    What are your listening habits, and what type of music do you listen to?
  • lanchile
    lanchile Posts: 560
    Get a used Bryston amp. or build a diy amp.:mrgreen:
    Make it simple...Make it better!
  • mara5
    mara5 Posts: 54
    Thanks all for the reply's. It will definately be seperates. I like to listen to CD's, and music from Satellite mostly. The whatever will be pushing KEF XQ40's, unless someone convinces me they're not the speakers for me. Haven't ordered or bought anything yet,to be honest I've been overwhelmed by the various choices.
    Perhaps my choice of words is wrong. Instead of receiver perhaps I should say a tuner (?), something that receives music, and is tunable to other channels (of music). I have O interest in HT, had it once didn't like it. I have a Yamaha RX-V870, but it lacks the pre-outs, and cannot drive the 40's, or so I'm told. The $1500ish is just for the receiver/tuner.Thx. guys.
  • pearsall001
    mara5 wrote: »
    Did you miss post #10 & #12???? The XQ40's are dynamite!!!!! Look no further.
