CDP fixed outputs or variable?
rebuy
rebuy Posts: 695
edited November 2011 in Electronics
My Sony ES has fixed and variable outputs, Is there an advantage to using variable over fixed?
Post edited by rebuy on
  • dorokusai
    dorokusai Posts: 25,576
    The Variable attenuation option allows you to control the volume when connected directly to an amplifier, from the CDP, voila' no Pre-Amplifier. No, there is no inherent benefit unless you're trying to do something in particular, or as alluded to above. This can easily be argued but I don't care personally what you choose at all. Fixed means fixed attentuation at the output and a set value or output, as in no surprises. Either way, good sound.
  • FTGV
    FTGV Posts: 3,650
    It depends if the attenuation is done in the digital or analog domains.With some vintage CDP's it was done in the digital domain which results in reduced resolution (lower bit rate).
  • dorokusai
    FTGV wrote: »
    Good point and information.
    tonyb Posts: 33,065
    FTGV wrote: »
    That still holds true today. Even with my Sonos, changing to a fixed from variable results in better resolution, as it's done in the digital domain.
  • steveinaz
    steveinaz Posts: 19,545
    If running into a preamp/integrated/receiver, use FIXED. If running directly into an amp, use VARIABLE.
  • rebuy
    rebuy Posts: 695
