no balance control
leftwinger57
leftwinger57 Posts: 2,917
edited November 2011 in Electronics
Hi guys, Thankfully I've been problem free for quite some time but it seems to rearing it's ugly head again.As the title says my Onkyo P-301 pre has somehow lost the balance control.I did remove each channel and they are coming through fine.Is it possible that the pod/pot control switch itself is beat or is there any thing else to check.Otherwise all the functions work whether I'm playing single cd or running through the tuner section for i-net radio or any other funtion for that matter.Thanks....
  • Glowrdr
    Glowrdr Posts: 1,103
    Did it used to work that you know of? Have you added and Y-splitters along the way that may have gotten crossed somehow? Just throwing some ideas out there.
    65" Sony X900 (XBR-65X900E)
    Pioneer Elite SC-37
    Polk Monitor 70's (2)
    Polk Monitor 40's (4)
    Polk Monitor CS2
    Polk DSW Pro 660wi
    Oppo BDP-93
    Squeezebox Duet
    Belkin PureAV PF60
    Dish Network "The Hoppa"
