Impressed with first set of DIY IC
ezc
Built a set of IC out of monster m1000 silver vid cable & monster m1000 quick loc compression ends. Have been trying to decide on what cable to use on & on & on. Thanks to doro & his suggestion "EZC - If you start counting strands, you shouldn't be building your own IC's. DIY is for pure enjoyment, don't get crazy or you will ruin the whole idea and the feeling. Build and believe." I used what we have here at the shop. My cables dont have any nylon covering or anything else. It looks like a 1 meter composite video cable. I listeded to my wifes cd Fleetwood mac "say you will" last night after installing the cables & I must say Im impressed! I hope as the cables break in it gets better. The sound stage has opened up & the depth was much deeper. With the monster 100's it sounded like playing through the dig or fiber optic cable & letting the receiver do the decoding. I dont listen to much music but hearing how big the sound was comming out of my system just blew me away! I actually listened to the whole CD! Im still in the wow zone! Im amazed that with just the mains playing the sound was that big! Wow. Built 4 more today & will hook it up to play a DVDA I purchased at CES. What is a good cleaner or what should I use to clean my rca inputs on the receiver & the dvd player? I do need to clean them, I used alcohol & a rag for a quick clean but i want to do a better job.
Mains LSi15
Center LSiC
Rear LSiFX
Receiver Rotel RSX 1065
DVD Player Yamaha DCV6480
Mains LSi15
Center LSiC
Rear LSiFX
Post edited by ezc on
Hi ezc.
I've been reading a lot about the Caig Laboratories products for cleaning / treating rca ends etc. You might want to research up on this cleaner:
http://www.caig.com/
Do a search for Caig under tweakers in Audio Asylum. Lots of info there. I think Parts Express also carries the product.
Paul -
I am really glad the project turned out, DIY is real neat and worth 10x if it turns out better than expected. It is always good to get your hands on things. Have fun Ace, enjoy the future projects. I have to manufacture cables for work from time to time, and it is really satisfying to have something you make, actually work.
PJ is on-time, with the CAIG reference, it's great stuff.
If you need a CONUS dealer for you new wires, let me know
CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
Yeah, I think I'm going to order some of the Detoxit and Pro gold to try out for myself.
Thanks for the info!!! Ill look into the caig products later today! My system needs a full cleaning. Not looking forward to taking all the equip off the rack & cleaning all the contacts & connectors but its time to do it!
Finally got a decent pic of my DIY IC! Very simple ic. Id like build another set using good cable, maby even multi stranded with different size conductors. Again looking for that slight improvment!Its never ending!
