What is this...??
starkiller
starkiller Posts: 2,723
edited November 2011 in The Clubhouse
Can anyone tell me what this is and where I can find more...??:mrgreen:
Computer room Hegeman 1 SpeakersM&K VX-80 subKenwood DP-7010Cambridge Audio CXC Transport Rega DACPrimaLuna Prologue Four AmpAric Audio Tube PreampGarage Jennings Research SquareCustom tube preampCrown XLS-1000Denon DCD-1500II Modded MSB Link DAC
Post edited by starkiller on
  • decal
    decal Posts: 3,205
    Some sort of hanging holder !!!!!!
  • mrbiron
    mrbiron Posts: 5,721
    Plate or Frame stand??
  • brettw22
    brettw22 Posts: 7,623
    I would guess towel holder
  • halo71
    halo71 Posts: 4,630
    Something from Harbor Freight?
    --Gary--
    txcoastal1 Posts: 13,507
    Napkin holder.....
    Whats up? Does anyone win anything?
  • starkiller
    Napkin Holder??? Nobody wins anything except a very heartfelt thankyou from me:mrgreen: As Rick88 mentioned, i will be using these to show off albums, will be using the two screw holes to mount them to a 2x4..gonna look great if I can find more of them!
  • dorokusai
    dorokusai Posts: 25,576
    Looks like something to hold a cookbook open or something like that on a counter.
  • Syndil
    Syndil Posts: 1,582
    If it can be found on the Internet, I can find it. My Google-fu cannot be touched.
    http://www.platestandsource.com/SteelScrollStand.php
  • Syndil
    Syndil Posts: 1,582
    BTW it's called a plate easel, and you can find many more similar to it by searching for such. Might try "wall plate easel" since it's wall mountable, or "scroll plate easel."
  • starkiller
    Syndil
    Many thanks! My special albums thank you also, though my checkbook doesn't:mrgreen:
  • Syndil
    Syndil Posts: 1,582
    Oh if you want cheaper, I can do cheaper, as long as you are OK with black instead of silver.
    http://www.bigceramicstore.com/supplies/PlateBowlHolders.htm $3.75
    I'd recommend that you double check the dimensions of the easel to get an idea of how your albums will fit in them. Plates come in many sizes, and so do easels.
  • dorokusai
    Syndil - Since you mentioned it....can you find a plate hanger(wall) for a plate that's very heavy and not cheap so it would have to be secure and better than a Home Depot variant? We have something we want to hang but don't trust what we've found offline and online so far. Maybe you can work some magic.
  • starkiller
    Well, I am going to try and be picky and find some EXACTLY like the pics I posted, they have that horizontal bar in front for support...maybe I will go to Michael's or Joanne's and such....
  • Syndil
    Syndil Posts: 1,582
    Dorokusai, are you wanting something of this design but stronger?
    http://www.homedepot.com/buy/tools-hardware-hardware-fasteners-fasteners-picture-hanging-picture-mirror/kohler-memoirs-2-piece-comfort-height-round-toilet-in-black-black-166832.html
    Or just something to hang a heavy plate?
    Starkiller, that horizontal bar is like a unicorn. Can't find it. But my pride is on the line, so I will keep searching.
  • starkiller
    Sounds good and if you do find it you will have to let me in on some of your secrets so I don't have to ask again when i am trying to find something!
  • Syndil
    Syndil Posts: 1,582
    Throwing in the towel on the plate easel with the horizontal bar.
    I was thinking about it while searching, and it may not be such a great idea after all. It would put two pressure points on your album covers where they met the stand, likely deforming them... Assuming we're talking about vinyl albums with cardboard covers.
  • dorokusai
    Syndil wrote: »
    Yes, a heavy plate and the OOK products are not good enough. The springs sag and where they get 30lbs is beyond me.
  • Strong Bad
    Strong Bad Posts: 4,278
    It looks like a reason to buy more junk to hang on walls!
    No excuses!
  • George Grand
    George Grand Posts: 12,258
    I'm waiting for the Ed Gein commemorative hanger/holder.
    tonyb Posts: 33,072
    Isn't that what they found that "Kung-fu" dude hanging up by in the closet ?
    Michael Hutchence, wall hanger
