Dared SL2000 left channel is gone!!! SUCKS!!!
Toolfan66
For some reason the left channel is gone!!!
Swapped cables, swapped tubes, swapped inputs and outputs!!! The other day I when I turned it on the left tube flared up then went to normal but no sound.. thats when I swapped tubes but still no sound out of the left channel..
what am I missing?? it sure sucks considering I have only played it a few times..
Post edited by Toolfan66 on
Do you have a DMM or oscilloscope handy? I can help you troubleshoot, just send me a PM.polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
Bummer that does blow....put a finger in one ear:cheesygrin:2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
Just a guess from previous experience, your tube might have blown a cathode resistor. Usually found soldered to the tube socket.Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 *
So I emailed the guy I purchased this from on audiogon and it don't seem he wants to help me out. This was not a used unit it was brand new and all he sells is new Dared equipment he even has a link from the Polk forum for reviews of the SL2000, Looks like I will have to take it in to be looked at as I don't have the tools to trouble shoot it..
Who did you buy it from? So he's not honoring the warranty? Is it in or out of warranty?
Please answer my other questions. I have worked with Joe on another Dared piece which I didn't even buy from him. A local Polkie also worked with Joe on a Dared piece he bought used.
Is it in warranty? I'm betting there is more to the story you're not revealing because if it's in warranty then he should honor it and so far you have given zero details.
What more could there be to the story?? I have only had this unit for two months, the left channel bit the dust. The unit has been working just fine in my rig one day I turned it on to let everything warm up as I always do and the left tube flared up it seemed to go back to normal but there is no sound coming from the left channel as I stated above. Don't know what more info you need or what you think I'm holding back.
I'm not sure what the warranty is on the unit as its not posted on his site nor is it posted in the manual. If I have to get it fixed my self fine but it is frustrating in the fact that it's only two months old, I'm sure you can understand that..
I'm not posting to throw him under the bus I'm posting about my problem in hopes to get it fixed is all. He did send me a phone number of some guy to call and see about getting it fixed if that's all he is willing to do then I will call this guy and see what he can do but There is a shop in town I can take it to to be looked at and I won't have to ship it out. -
I think at the minimum it should have a 90 day warranty. I do know they don't do repairs on site and he recommends a guy in the same area to do the work. A local Polkie had to have his used Dared Sl2000A repaired for the same issue but the previous owner used the wrong rectifier which I believe caused the issue. That's why I wanted more info from you. So Joe basically said he's not paying for it? Did you ask him what the warranty is? I would not roll over that easy. I have worked with Joe before and so has the other Polkie and hes has been nothing but responsive and accommodating.
Hmmmmmmmmmm.....it took me literally 10 seconds to find this info.
http://www.dared.us/services.htm
I don't think you are trying very hard.
Good Luck
Tool
You ever get this straightened out???Main Rig-Realistic AM/FM Record player 8 track boasting 4 WPC
I’M OFFENDED!!!! -
Yes I mailed it out yesterday for warranty fix or exchange. Joe said he would take care of it!! I will update when I get it back.
BTW I have a PM coming your way.. -
Joe sent me an email with FedEx tracking # and informed me that my "NEW" Dared SL2000 is on it's way!!!!:cheesygrin:
Joe is the man.. -
Did Joe say if it was a known problem with the dared?
He said this is a first.
Joe is the man..
Excellent!Main Rig-Realistic AM/FM Record player 8 track boasting 4 WPC
I’M OFFENDED!!!! -
That's pretty d*** nice of him to do that. One thing to fix it another to replace it. He (Joe) must be a class guy.Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable -
It will be here tomorrow ...
Wife called and said its sitting on the table waiting for me to get home.. WooHoo!!!
I could take this statement to the gutter Larry but i won't! :cheesygrin:Main Rig-Realistic AM/FM Record player 8 track boasting 4 WPC
I’M OFFENDED!!!! -
Joe is the man..
I told you..........:cheesygrin:
:biggrin:
That is good news Larry!!:cool:
Up and running and all is good so far!!! I hate having a piece of gear missing in my rig.
Thanks Brock... -
Larry, does this guy sell on ebay as "midwestsupport" out of Naperville, ILL? I know you bought on A-gon but thought he might sell elsewhere. I am looking at purchasing one of these and noticed he had a customer return for a failed SL2000 in September this year. Are these maybe hit and miss with quality?SRS 3.1TL
Harman Kardon Citation 5.1
Anthem AVM2 -
Yes,
That's Joe Zhou who is an authorized Dared distributor and is in Naperville Illinois. Buy with confidence. It's hard to say why they failed. Our very own Daboyz had an input coupling cap blow, it was an Auricap which is a very high end cap. The problem was the previous owner ran the wrong rectifier, sold it with the wrong rectifier and when I saw it told Dave to switch it immediately, which he did, but a few months later one channel went out. His issue was solely from the prior owner using the wrong spec rectifier (5AR4) instead of the proper 5Z4. I am not saying all faliures are due to mis-use, but with tubes it certainly can be an issue, not to mention a bad tube can cause issues too.
Just some food for thought.
FWIW, I own 3 Dared pieces all used and they have been stellar.
Stubby i got mine from Joe on Ebay.He had it listed at 469 obo.i offered 425 plus 25 shipping and got it.i may have been able to do better but i am tickled silly with my 450 purchase.i have 2 other pre's that are not as sweet sounding as this dared with stock tubes and i paid more for both of them.YMMVMain Rig-Realistic AM/FM Record player 8 track boasting 4 WPC
I’M OFFENDED!!!! -
Thanks for the bodes of confidence in Dared products. It is on my list of pre's to consider. Also looking at VTL 2.5 and Marsh P2000, if I can find one used at a decent price. I know the Marsh isn't tube but many have praised it's warmer character. IE, it does not sound solid state.
stubbySRS 3.1TL
Anthem AVM2 -
The VTL is a nice piece. I'd avoid the Marsh, I've read about too many problems with that particular pre."Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul!
Do you recall what kind of problems people had with the Marsh? All my searches (including here) have shown positive regards. Frankly, the Dared has been the least reliable of any of the pre's I've looked at.The VTL is a nice piece. I'd avoid the Marsh, I've read about too many problems with that particular pre.SRS 3.1TL
Anthem AVM2 -
The Marsh is a hybrid pre-amp where the input section is tubes but the output is solid state so it's not as tubey sounding as a full tube pre. Also where the Dared really shines is that it uses tube rectification. That's part of what gives it such great tone.
http://forum.audiogon.com/cgi-bin/frr.pl?rprea&1055776127&&&/Marsh-Sound-Design-P-2000t-Tube-preamp
http://ns1.audiokarma.org/forums/showpost.php?p=3296689&postcount=32
http://ns1.audiokarma.org/forums/showpost.php?p=3299980&postcount=36
Just a couple I could google. I just remember reading some specific issues about the reliabilty and build of the P 2000T that sort of made me avoid it. I'm sure it wasn't all bad, but if IIRC small little build issues that at that price point shouldn't have happened. Not sure if there is support for the products today or not.
I can only speak to what I know of the Dared, and that has been that's it's a solid performer, well built and sounds well outside it's price point if you put some good tubes in it.
Good luck with you search
H9, sorry for not being more specific about which model I was speaking of! I was looking at the p2000b all solid state pre. I had noticed some complaints as you refered to with the hybrid. The solid state looks to be much better.SRS 3.1TL
Anthem AVM2
