Ohm Setting
deronb1
deronb1 Posts: 5,021
edited December 2011 in Electronics
I think this has been touched on before, but I can't remember. My fronts are 6 ohm, center and rears 8 ohm. Should I set my AVR to 6 or 8 ohms? Does it really matter?
Post edited by deronb1 on
    tonyb Posts: 33,065
    edited November 2011
    Yes, it matters. Leave it at 8 ohms.
  • deronb1
    Aight, switching to 8 ohms. Thanks.
    tonyb Posts: 33,065
    Good man, when you switch it to 6 ohm, you are limiting the current the receiver sends to the speakers. You want as much current as possible to hit your speaks.
  • deronb1
    Makes sense to me. Have a great Thanksgiving!
  • chadam44
    chadam44 Posts: 68
    Switching to 6 ohms limits the output of your receiver so that it does not damage itself. Leave it at 8ohms to keep it at full power and keep an eye out for any heat issues with the receiver.
