Ohm Setting
deronb1
I think this has been touched on before, but I can't remember. My fronts are 6 ohm, center and rears 8 ohm. Should I set my AVR to 6 or 8 ohms? Does it really matter?
Post edited by deronb1 on
Yes, it matters. Leave it at 8 ohms.HT SYSTEM-
lsi 9's -
Aight, switching to 8 ohms. Thanks.
Good man, when you switch it to 6 ohm, you are limiting the current the receiver sends to the speakers. You want as much current as possible to hit your speaks.HT SYSTEM-
lsi 9's -
Makes sense to me. Have a great Thanksgiving!
Switching to 6 ohms limits the output of your receiver so that it does not damage itself. Leave it at 8ohms to keep it at full power and keep an eye out for any heat issues with the receiver.
