Bi-Amp Tsi 500
fanisius
I have my Tsi-500 Speakers bi-amped using an Adcom GFA-535L on the top poles and a GFA-545 on the bottom poles. Both amps are sending a signal but I can only get sound from the bottom poles. Nothing from the top. If I connect either amp to the bottom poles I get sound. If I connect either to the top poles I get no sound. I am testing this with a static white noise signal, so shouldn't I hear something from the top poles? Even if is the tweeter? Why do I only get sound from the bottom poles?
Post edited by fanisius on
Sounds like you have either blown tweeters, or a wiring issue. What happens if you put the plates back in that link the poles?Main Surround -
Den - Rotel RSP-1068 / Threshold CAS-2 / Boston VR-M60 / BDP-05FD -
Post 3 reported.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
