8 inch sub
LONG TIME BUYER
Need advise; i am putting a 8 inch sub in my truck. This is the only size that i want. I am looking at 2 brands. Jl audio and polk audio. The 2 that i am looking at ,and getting reviews on are ,polk audio mm840,and jl audio 8w3v3. The reviews on both of these are pretty much the same. The price differents is around $100.00. I will be using a 400 rms mono amp to push them, and put in a sealed box. What is the right choice?
Post edited by LONG TIME BUYER on
IF both have same reviews and specs but JL is $100 more it's a no-brainer to me - Polk all the way.
While JL makes good products they do add additional fee for their name
so in reality both subs are probably same in performance AND price, but you are stuck with paying "JL AUDIO" fees for using their name. 2008 Nissan Altima
Kenwood DNX 5140
Arc Audio IDX and XEQ
Polk Audio SR6500 active and SR124-dvc sealed
Polk Audio PA500.4 and PA1200.1
