glowrdr
leftwinger57
thanks forthe head upon the setting page . I followed all your instructions and at first went over the limit then revise the content but now I can't seem to look it in for all to see . I know I'm missing something very simple but again no genius here so if your awake or could respond that would be great. I know I'm with inthe allotted amount of words so thar's not the problem.
Was kind of suprised when I was browsing the forums and found my name. lol
It's there, so I think you're in luck.
But, just in case - if you go back to your settings (where you edit your signature), and click on "General Settings", about 3/4 of the way down the page you will see "Thread Settings". There you can check the box to add your signature or not. By default, I believe it is on. But that is where you can double check the settings if you wanted.
After reading, I think that may just be to show other people's signatures, not your own. So your's is turned on, but you may not be choosing to see it.65" Sony X900 (XBR-65X900E)
Pioneer Elite SC-37
Polk Monitor 70's (2)
Polk Monitor 40's (4)
Polk Monitor CS2
Polk DSW Pro 660wi
Oppo BDP-93
Squeezebox Duet
Belkin PureAV PF60
Dish Network "The Hoppa" -
I kinda like seeing my system progress over the last 2 years. Can't wait for the praverbeal ship to come in and then you'll really see a signature .Thanks again it does make things alot easier....lw2chl- Adcom GFA- 555-Onkyo P-3150v pre/amp- JVC-QL-A200 tt- Denon 1940 ci cdp- Adcom GFS-6 -Modded '87 SDA 2Bs - Dynamat Ext.- BH-5- X-Overs VR-3, RDO-194 tweeters, Larry's Rings, Speakon/Neutrik I/C- Cherry stain tops Advent Maestros,Ohm model E
