can u change the speaker size on ur door?
ipartywhenuhurt
I have an olds mobile intrigue 2000 and the front doors are 5.25 and i need them to be 6.5 since i just recently purchased a new sr6500 and I want to install them, anyway to make the change
any other options than custom kick panels? Since I can?t find any for my car
Post edited by ipartywhenuhurt on
Yes, have custom kick panels created out of fiberglass.Main Surround -
Den - Rotel RSP-1068 / Threshold CAS-2 / Boston VR-M60 / BDP-05FD -
He asked any other option besides custom kick panels.
you can try these
http://www.sonicelectronix.com/item_39167_Xscorpion-SP-AD6054.12.htmlTV: Philips 42" LCD 1080p
Front Speakers: Polk Audio RT800i
Center Speaker: Polk Audio CS1
Surround Speakers: Polk Audio R50's powered of Denon AVR
Subwoofer: Polk Audio DSW pro500
AVR: Denon 3801
DVD Player: Denon DVM 745 upscale 1080p
Sat: Directtv HD 10
Front Speakers Amp: Rotel RB 890
Center Speaker amp: Rotel 970 BX -
Thank you greg :)Do so these work just by adding them to the doors? Increasing the size of the hole? They seem to be just what im looking for I really appreciate it greg XD
Got a pair for 15.90 from ebay hope they work XD thanks greg I had no clue they existed
How much do custom kick panels cost normally?
Back in the day, I had an 83 Cutlass that I had some MBQuartz put in the door that required kickpanels. I think they only charged me like 200 for the install. Granted, these were just wooden, carpeted kick panels (looked decent though), not some custom formed fiberglass - but if you check around, it's really not all that bad.65" Sony X900 (XBR-65X900E)
Pioneer Elite SC-37
Polk Monitor 70's (2)
Polk Monitor 40's (4)
Polk Monitor CS2
Polk DSW Pro 660wi
Oppo BDP-93
Squeezebox Duet
Belkin PureAV PF60
Dish Network "The Hoppa" -
So if I wanted to go that route 200-300 would be the price .......not too bad.
Will they sound better than adding the adapter do you think? Since it has more cubic ft to work with? -
ipartywhenuhurt wrote: »Thank you greg :)Do so these work just by adding them to the doors? Increasing the size of the hole? They seem to be just what im looking for I really appreciate it greg XD
Yes thats how they work I use them in my car with some polk MM 52151 component, I added some rubber gaskets and they sound great but the inside of my doors are dynamatted..:biggrin:TV: Philips 42" LCD 1080p
AVR: Denon 3801
Sat: Directtv HD 10
ipartywhenuhurt wrote: »So if I wanted to go that route 200-300 would be the price .......not too bad.
I think the kickpanels would sound better a car door is not the ideal speaker box its probally the worste..
AVR: Denon 3801
Sat: Directtv HD 10
How much is the dynomate? And u put it inside the speaker holder or just outside? How much would I need?
I need rubber gaskets?
ZoThey were the wrong thing there for changing 6-1/2 to 5-1/4 :::(((((((( supper sad
Yeah, you'd be looking at either cutting the hole in the door larger, or using some sort of "adaptor" - but that would end up looking weird. Actually, I'm not even sure that would work well because the back of your speaker would be pushing up against plastic, and you might end up with some adverse "port noise" effects from it.
I'd call around and find out a real cost of the kick panels / door panels. There are enough aftermarket options out there, it should keep the cost down.65" Sony X900 (XBR-65X900E)
Pioneer Elite SC-37
Polk Monitor CS2
Polk DSW Pro 660wi
Oppo BDP-93
Squeezebox Duet
Belkin PureAV PF60
