Probably a dumb question
Tennhioland
Tennhioland Posts: 1
edited November 2011 in Speakers
I have an Onkyo TX-SR600 receiver, monitor 70s in the front, monitor 40s in the back, and a CS2 center. No sub at this point.
My question, when I do get a sub and adjust all the settings, will the monitor 70s now sound a lot better because the four drivers will be dedicated to mid frequencies, instead of having to handle the lows as well? I know the system will sound better with the sub, but just curious if you're getting a 2 for 1 improvement with better bass, and allowing the fronts to worry about the mids and highs only.
Make any sense? Thanks.
Post edited by Tennhioland on
  • Glowrdr
    Glowrdr Posts: 1,103
    Yeah, you should notice a couple of things. The sounds will be more defined because of the seperation, and they should be louder/clearer because you would be just powering the mids/highs which are the least of your power concerns. Takes the wieght off the shoulders of your AVR basically.
    65" Sony X900 (XBR-65X900E)
    Pioneer Elite SC-37
    Polk Monitor 70's (2)
    Polk Monitor 40's (4)
    Polk Monitor CS2
    Polk DSW Pro 660wi
    Oppo BDP-93
    Squeezebox Duet
    Belkin PureAV PF60
    Dish Network "The Hoppa"
  • Jonn Wain
    Jonn Wain Posts: 41
    There are no dumb questions. Wait a minute, yes there are, I ask them all the time !!!!
  • pearsall001
    pearsall001 Posts: 5,327
    Sounds like you might be on to something. http://www.ecoustics.com/electronics/products/articles/128214.html. Nothing is set in stone so play around with the XO settings & go with what sounds best. I'll bet it's either 60/80hz though.
    Welcome to Club Polk!
    Phil is absolutely right!
    Even though M70s are rated to 40hz +/- 3db, remember that it takes more and more POWER to provide a 40hz tone at the same loudness as mid/higher frequencies. This is most notable when you add a power amp into the mix with an AVR. Even with my Onkyo 805 which is quite the power master, a 200 watt x 2 (8 ohm), power amp driving the M-70s as Full Range speakers tightens up their low bass and gives it more 'authority'. So yes, adding a sub and running the M-70s at 60hz or higher will make things sound better.
    Have fun!
    cnh
