how to ty in multipleamps to achive h/t seperates
leftwinger57
leftwinger57 Posts: 2,917
edited November 2011 in Electronics
Guys I've been on the forum for a while now and keep hearing about combining multiple amps to make for a more powerful h/t system. For me a very simple minded guy how is this done.If you have 2 chl amp for the fronts and then a 3chl for center and surrounds how do you bond all these amps and then incorperate them into an avr into the mix. I might be so totally wrong but I would like to know in the simplest of ways.And this does seen like a very expensive way to go instead of getting a dedicated 5-chl amp. If not to much trouble could you please enlighten me.I actually had trouble enough going from my Yamaha pre-outs to my Adcom that I went w/ the Onkyo p-391 pre.
    tonyb Posts: 33,065
    The same way you hooked up the adcom. You have to have a full set of preouts, Front left & right, Center, back left and right. Speakers get hooked up to the amp and you use a coax cable from the preouts on the receiver to the line in on the amp.
  • BlueFox
    BlueFox Posts: 15,251
    And then use an SPL meter to balance all the speakers.
  • jbooker82
    jbooker82 Posts: 1,627
    Use the 3 channel amp for the L,C,R. And a 2 Channel amplifier for the surrounds.
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
    Sub: Polk DSW Pro 660wi
    TV: LG Infinia 50PX950 3D
    IC: AudioQuest Black Mamba II
  • drummer86
    drummer86 Posts: 441
    jbooker82 wrote: »
    I'm guessing the 2 ch amp is more powerful or he'd be doing this already...?
    Display: LG 47" LCD | AVR: Marantz SR5005 | BD: Panasonic BDT-210 | CD/SACD: Oppo 980 |
    Amps: Rotel RB-990bx | Marantz MA-500 | Speakers: Totem Mite : Totem Mite-C : RC60i | Sub: HSU VTF-2 MKIV
    HK AVR635 | Polk R30 | Sony DVD/SACD Player
  • leftwinger57
    I'm totally missing something here. I get that the speakers go directly to the amps. then you plug your preout from lets say gfa555 were does the preouts go to bondall these amps together. A very simplemind at work here.
    tonyb Posts: 33,065
    From the receiver........don't think I could explain it any simpler. The receiver or pre will have 5 speaker preouts, marked as such on the back that connect to an amp. Not ALL receivers have them, yours may not, if so, your out of luck.....which is why we always recommend buying a receiver with preouts.
