Time for an upgrade
dskns26
I currently have a Harman Kardon AVR 235 and I am looking to upgrade to something more up to date. I like the HK but I am open to other brands as well. I am looking for 7.1 and I use it for about 75% movies/tv and 25% music. My fronts are Polk Monitor 60's, center CS10, surrounds are old HTIB Sony satellites that I am also looking to upgrade and a BIC PL-200 sub. My living room is 30x14 but is open to other rooms. Any suggestions or thoughts would be greatly appreciated.......Thanks!
Post edited by dskns26 on
Welcome to CP!
If you want to stay with HK check out their ebay store. You can get great prices on refurbed AVR 254/354s with factory warranties. Your price range would help to give more specific advice. Happy hunting!Display: LG 47" LCD | AVR: Marantz SR5005 | BD: Panasonic BDT-210 | CD/SACD: Oppo 980 |
Amps: Rotel RB-990bx | Marantz MA-500 | Speakers: Totem Mite : Totem Mite-C : RC60i | Sub: HSU VTF-2 MKIV
HK AVR635 | Polk R30 | Sony DVD/SACD Player -
What are you looking to spend? Newegg has the Pioneer VSX-1021-K for $300 use promo code EMCJJJJ24
It is a nice unit and has gotten good reviews so far.Absolute corruption empowers absolutely.
Lg 55LW5600 TV
Onkyo PR-SC 5508
Legacy Audio Focus SE
Legacy Audio Silverscreen HD center
Polk F/X500i Rears
Parasound HCA-3500
Sunfire Grand Cinema
Behringer iNUKE NU6000DSP
Pair of CraigSUB SS-18.1 -
Here's HomeTheater's review of the 1021. Take it for what it's worth but many seem to find the power lacking a bit.
http://www.hometheater.com/content/pioneer-vsx-1021-av-receiver
HT Labs Measures
Five channels driven continuously into 8-ohm loads:
0.1% distortion at 46.1 watts
1% distortion at 56.7 watts
Seven channels driven continuously into 8-ohm loads:
0.1% distortion at 44.5 watts
1% distortion at 53.7 wattsDisplay: LG 47" LCD | AVR: Marantz SR5005 | BD: Panasonic BDT-210 | CD/SACD: Oppo 980 |
That is odd the one I seen listed on newegg has different specs. It was listed at 110work watts per channel the one they reviewed was not the 1121-k are they the same?Absolute corruption empowers absolutely.
Lg 55LW5600 TV
Onkyo PR-SC 5508
Polk F/X500i Rears
Parasound HCA-3500
Can't edit with my phone I wanted to say 1021-kAbsolute corruption empowers absolutely.
Lg 55LW5600 TV
Onkyo PR-SC 5508
Polk F/X500i Rears
Parasound HCA-3500
That's the approximate rating for running two channels. As you can see it drops considerably when you spread that out over 5 or 7. All depends on how the company rates their amps.Display: LG 47" LCD | AVR: Marantz SR5005 | BD: Panasonic BDT-210 | CD/SACD: Oppo 980 |
The 1021 will work great had the 1020 for my HT powering my LSi equipment for a week while waiting on my SC-35 and Sunfire2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
"Advertised Specs" and "actual output" are two totally different things my friend. A receiver that actually puts out 110 watts per channel all channels driven would A) cost $3000 not $300, and
weigh about 60lbs+. Main Surround -
Den - Rotel RSP-1068 / Threshold CAS-2 / Boston VR-M60 / BDP-05FD -
How much money do you want to spend?
Do you mind buying used, or does it have to be new?
I am looking to spend $700 at the most. I have never thought of getting used but if it were to come with a warranty I would be open to that. Any thoughts on Denon avr-1912? As for the Pioneer, I wasnt sure if I needed to look at the Elite line as opposed to the regular line?
What ever you do, get a receiver with pre outs otherwise you limit yourself to what speakers you can upgrade to in the future. Speaking of speakers, the ones you have now seem a tad on the light side given those room dimensions and open areas.HT SYSTEM-
lsi 9's -
$700 bucks will get you a used (referbished) Onkyo TX-NR809 with a 5 year warrenty. 135 watts per channel. 7.2 analog outputs, Audyssey MulitEq XT automatic setup, 4k upscaling, powered 2nd zone, 192/24 bit Burr-Brown DAC
http://www.accessories4less.com/make-a-store/item/ONKTXNR809/Onkyo-TX-NR809-7.2-Channel-Network-A/V-Receiver/1.html#!moreAVR: Onkyo Tx-NR808
Rear: FXI A4
Sub: Polk DSW Pro 660wi
TV: LG Infinia 50PX950 3D
IC: AudioQuest Black Mamba II -
Thanks for all the input. I have been thinking the same thing about upgrading the fronts and center due to room size but budget becomes a concern for me. I can save a little on an AVR and get the onkyo tx-nr 609 for $380 from Newegg and put savings towards new speakers. Any thoughts on the 609?
