how to ty in multipleamps to achive h/t seperates
leftwinger57
Guys I've been on the forum for a while now and keep hearing about combining multiple amps to make for a more powerful h/t system. For me a very simple minded guy how is this done.If you have 2 chl amp for the fronts and then a 3chl for center and surrounds how do you bond all these amps and then incorperate them into an avr into the mix. I might be so totally wrong but I would like to know in the simplest of ways.And this does seen like a very expensive way to go instead of getting a dedicated 5-chl amp. If not to much trouble could you please enlighten me.I actually had trouble enough going from my Yamaha pre-outs to my Adcom that I went w/ the Onkyo p-391 pre.
The same way you hooked up the adcom. You have to have a full set of preouts, Front left & right, Center, back left and right. Speakers get hooked up to the amp and you use a coax cable from the preouts on the receiver to the line in on the amp.HT SYSTEM-
lsi 9's -
And then use an SPL meter to balance all the speakers.Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
Use the 3 channel amp for the L,C,R. And a 2 Channel amplifier for the surrounds.AVR: Onkyo Tx-NR808
Rear: FXI A4
Sub: Polk DSW Pro 660wi
TV: LG Infinia 50PX950 3D
IC: AudioQuest Black Mamba II -
I'm guessing the 2 ch amp is more powerful or he'd be doing this already...?Display: LG 47" LCD | AVR: Marantz SR5005 | BD: Panasonic BDT-210 | CD/SACD: Oppo 980 |
Amps: Rotel RB-990bx | Marantz MA-500 | Speakers: Totem Mite : Totem Mite-C : RC60i | Sub: HSU VTF-2 MKIV
HK AVR635 | Polk R30 | Sony DVD/SACD Player -
I'm totally missing something here. I get that the speakers go directly to the amps. then you plug your preout from lets say gfa555 were does the preouts go to bondall these amps together. A very simplemind at work here.2chl- Adcom GFA- 555-Onkyo P-3150v pre/amp- JVC-QL-A200 tt- Denon 1940 ci cdp- Adcom GFS-6 -Modded '87 SDA 2Bs - Dynamat Ext.- BH-5- X-Overs VR-3, RDO-194 tweeters, Larry's Rings, Speakon/Neutrik I/C- Cherry stain tops Advent Maestros,Ohm model E
leftwinger57 wrote: »I'm totally missing something here. I get that the speakers go directly to the amps. then you plug your preout from lets say gfa555 were does the preouts go to bondall these amps together. A very simplemind at work here.
From the receiver........don't think I could explain it any simpler. The receiver or pre will have 5 speaker preouts, marked as such on the back that connect to an amp. Not ALL receivers have them, yours may not, if so, your out of luck.....which is why we always recommend buying a receiver with preouts.HT SYSTEM-
