Power Management Equipment
PreCd
PreCd Posts: 786
edited November 2011 in Electronics
What is everyone using to manage the power to their gear? I am looking for something to manage the power up and down of my gear. Nothing fancy needed just reliable.
SDA2BTL
Marantz CD5004
Adcom GFA-545
Bottlehead Quickie Tube Preamp
Post edited by PreCd on
    pitdogg2 Posts: 26,925
    I just use my finger:idea: ...it hasn't failed me yet:cheesygrin: and if it does i have several left
    EndersShadow Posts: 17,687
    APC H15 is what I am using. I like that its got voltage regulation as well as a 12v trigger for 2 outlets.
  • Lietuvis91
    Lietuvis91 Posts: 909
    I have the Belkin PureAV Home Theater Power Console PF60. Not a 100% sure, but I think it has a 12v trigger. I only bought it because amazon had a really big sale on these, for like $130 or so, and I was running out of oulets on my surge protector. I was very surprised at how it cleaned up the sound of the system. I guess they named it "PURE" for a reason.
    Living Room 7.1 HT Rig:
    M70 | CS2 | M60 | Atrium5 - Surr. | SUB - Emotiva ULTRA12 + Tara Labs sub cable | Pioneer Elite VSX-52 | Parasound HCAs 1000A | Sony BDP-S790 | Belkin PureAV PF60 | MIT Exp2 Wires
    Bedroom 5.0 HT Rig (Music/Movies/Gaming) :
    LSi9 | LsiC | Lsi/fx | Marantz SR7002 | NAD T955 | Sony BDP-S360 | Belkin PureAV PF30 | AQ Blue Racer II ICs & AQ Type 4 wires | PS3
  • inspiredsports
    inspiredsports Posts: 5,502
    I think APC H10's or H15's are the no-brainer sweet spot for most. They are basically properly engineered and perhaps a bit underpriced. You can spend up to 10X what you will spend for an APC to get to the next rung.
    Conrad Johnson PV-5 w/mods
    MF x-DAC V8, HAInfo NG27
    NAD SS rigs w/mods
    GIK panels
    Just as an aside the main difference between the Belkin P60 (which I also considered) and the H15 is voltage regulation. If voltage regulation doesnt matter to you the P60 is cheaper and has all other functions the H15 has I believe.
    I am not sure if the H10 has voltage regulation or not.
    tonyb Posts: 33,065
    I use a PS Audio Quintet.....does what it's suppose to do.
  • PreCd
    PreCd Posts: 786
    Thanks for the suggestions guys. I will take a look at these and go from there.
    SDA2BTL
    Marantz CD5004
    Adcom GFA-545
  • inspiredsports
    H10 also has voltage regulation.
    NAD SS rigs w/mods
    GIK panels
    tonyb Posts: 33,065
    When looking for power conditioners/regenerators, I have learned the hard way to stay away from the mov based units. Once they take a direct hit, or even a few hundred feet away lightning strike, they are toast. Spent 500 clams on Monster's top conditioner to find this out the hard way. I know we have a few threads around here talking about mov based units. Something to consider anyway.
  • Upstatemax
    Upstatemax Posts: 2,731
    I have two APC H15's. One in my HT and one in my 2Ch rig and I'm very happy with them.
    Voltage regualtion was important to me and the H15 was a "no brainer" for me and my budget.
  • inspiredsports
    MOV-based (metal oxide varistor) protecters remind me of the hated poly-switches we remove from our crossovers. They quickly degrade with use and don't always protect you properly. Most simple surge protection powers strips are MOV's.
    NAD SS rigs w/mods
    GIK panels
