The mother of all KT88/6550 has arrived
  • thsmith
    thsmith Posts: 6,082
    edited November 2011
    Shuguang Treasures....better than the originals.
    I have yet to find a 6SN7 that is as quiet and sounds better than the Treasure CV varients.
  • zingo
    zingo Posts: 11,258
    Their tubes are very good. Right now I'm trying the only other new tubes I would buy, the Gold Lions. Their KT77s are burning in nicely, but I'd love to compare them directly to the Treasure 6CA7.
  • chargerman426
    chargerman426 Posts: 419
    headrott wrote: »
    What was wrong with your transaction(s)? Also, are you refering to Upscale Audio or Brent Jesse?
    Greg
    "Upscale" audio. Brent Jesse's site it a wealth of tube knowledge. As far as Upscale like I said before.
    "bought my PrimaLunas from there and every time I would ask about trying tube A or B in it since its "a tube rollers dreams" and he says if you brake it your screwed." Not really a tube rollers dream if you want to try different things and are told "no even though that is drop in replacement you can't use it."
    If life had more tubes it would be a lot smoother.
  • thsmith
    Whats the veridict on the KT120s ?
  • janmike
    janmike Posts: 6,146
    I will probably get them, it's just a matter of where.
    Michael ;)
    NORTH of 60°
  • janmike
    Actually, just order 4 matched pairs from Upscale. I like their testing procedures.
    Michael ;)
    NORTH of 60°
