Would you recommend a wireless router?
apc
apc Posts: 779
edited November 2011 in The Clubhouse
We've got a Windows based laptop and 2 desktops, a macbook, an iphone, ipod touch and ipad2 and a VZW network extender - all of which are out of commission since my Linksys wireless router went on the fritz last night.
Anyone care to suggest a suitable replacement?
Husband, Father, Son, Brother, Friend.
Post edited by apc on
    EndersShadow Posts: 17,698
    apc wrote: »
    Personally I like Linksys. I had a WRT54G for years, in fact my dad still has one. So I would get a wireless n linksys router. I also had a D-link router at one point that was wireless-n. Did a decent job but I only had it for like 2 weeks till I had to remove it since uverse installs a wireless router/hub with their internet/cable service.
    Either way I suggest hardwiring as many of those devices as possible via ethernet.
  • apc
    apc Posts: 779
    Thanks. I got a call from a techie friend who suggested a combo modem/wireless router from my ISP. I phoned Knology and they have this one:
    ARRIS Touchstone? DG950 Data Gateway
    Sounds like a good alternative. Anyone have experience with similar device?
  • nguyendot
    nguyendot Posts: 3,594
    Aruba makes awesome devices...will cut through interference like a hot knife through butter. Might be a bit much for you though!
    I use WRT54G's with dd-wrt, as well as a WRT150N with DD-WRT. very stable, very good speeds. Kinda old though.
    Main Surround -
  • rebuy
    rebuy Posts: 695
    We always use Linksys, good stuff.
  • apc
    apc Posts: 779
    I have enjoyed my Linksys WRT150N, which may have just gotten zapped by a power surge. The power indicator LED is faint, which may be an indicator.
  • DaveHo
    DaveHo Posts: 3,583
    Bought a ASUS RT-N56U a few weeks ago. No complaints so far. Excellent speed.
  • Mr. Sharpe
    Mr. Sharpe Posts: 1,359
    haha, no Belkins here? I use a belkin 600 i believe it is and it's super fast. but I hear Linksys is better, idk, this one we have works very well. just use a surge protector. we've had 2 D-links burn out during storms.
    Home theater:
    43” Westinghouse Displayer
    Marantz UD-7007 Player
    Emotiva MC-700 Processor
    Adcom GFA-5006 Amplifier
    Parasound Zamp Amplifier
    Ethereal ESO-1 Power Conditioner
    Klipsch RC-10 Center
    Klipsch R34c Fronts
    Klipsch RB-41 Surrounds
    Polk audio PSW-505
    Stereo:
    Polk audio RTA-12c’s fully upgraded crossovers
    DIY 12tc braided speaker cables
    Denon DVD-5910ci Spinner
    Parasound P6 Preamplifer
    Parasound HCA -1500a Amplifier
  • BeefJerky
    BeefJerky Posts: 1,320
    This is really hard to answer. It seems that different people can have significantly different experiences with exactly the same wireless router. What works for me may not work for you, and vice versa.
    I've had good luck with Netgear myself, though I'm aware that it can be hit or miss with them when it comes to firmware. However, with a good firmware version, their products work very well. And, don't upgrade to a newer version until you've read others experiences, but this is good advice for any brand. Right now I am using a Netgear WNDR3700v1 and it works great. It is very fast and has good range. Plus, it has the 5GHz band which is a requirement for me; there is just too much interference on the 2.4GHz band.
    That being said, the only brand of wireless router that I have had consistently bad experiences with is D-Link. However, their small business line of wired ethernet equipment is very good. I have a 16-port D-Link gigabit switch and it's been great.
  • Willow
    Willow Posts: 11,227
    I had the same issue as the OP, we just went with the rental of one from our cable/internet provider. Seems to be working very well thus far and I think it is made by cisco, it says SMC on the front...that is all I can remember
  • apc
    apc Posts: 779
    Knology tech is scheduled to bring out the one I mentioned above this morning. The way I see it, they have to replace it if it is damaged since it's leased. I also get rid of one extra device and it's power wall wart!
  • Mr. Sharpe
    We would've kept the Rental from the provider, but low and behold, it was a D-link:D
    Home theater:
    Klipsch R34c Fronts
    Polk audio PSW-505
    Stereo:
  • jwhitakr
    jwhitakr Posts: 568
    Had a Linksys WRT54G that we used for about 4 years, and it finally gave out. Got a Cisco E1000 refurb and it's actually worked better than the WRT54G. Better speeds (which I would expect since it is a 'N' instead of 'G' speed) and the signal strength is better.
    No complaints with either model. Just make sure you get the 802.11N and that it is backwards compatible with 'G' and 'B' also.
    My HT
    HDTV: Panasonic PT-61LCX65 61" Rear Proj. LCD
    AVR: Harman Kardon AVR 235
    Video: 80GB PS3, Toshiba HD-XA1 HD DVD
    Fronts: Polk Audio RTi8
    Center: Polk Audio CSi3
    Amp: Emotiva LPA-1
    Surrounds: Polk Audio R150
    Sub: HSU STF-3
    The only true barrier to knowledge is the assumption that you already have it. - C.H. Dodd
