How did we ever make it without...
rebuy
audyssey or those other correction devices. What would the younger crowd do without it?
We actually had to rely on what sounded good to us.
Post edited by rebuy on
Yep and if your part deaf in one ear it sounds odd to everyone else.AVR: Onkyo Tx-NR808
Rear: FXI A4
Sub: Polk DSW Pro 660wi
TV: LG Infinia 50PX950 3D
IC: AudioQuest Black Mamba II -
Actually I don't care much for what MCACC does to the EQ and what not.
Same way we do now. Use an SPL. Nothing wrong with auto-calibration, but it is good to check. However, I suspect for 99.99% of the population, the auto-calibration software gives better results than manual adjustment. Technological progress is the name of the game. Besides, auto-calibration has only been around for a few years.Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
We trusted our ears and made adjustments so it sounded good to us. Back in the mid 70's stereo days I had a Soundcraftsman equalizer. It had 10 sliders per side so you could adjust frequency ranges. Man that was fun!
Audyssey is great...for home theater. The biggest improvement was how it cleaned up the low end. Can't say I like music through any receiver or pre-pro though."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
I've never used auto-eq before so I'm not the most informed, however I am sure I would rather do the setup myself. If I did go through an auto-eq process, I would assuredly have to carefully examine the settings it decided on and see how they line up with my own findings.
Has anyone set up their HT themselves, and then run the auto-eq to see what changes it made? -
Auto calibration is a nice feature upgrade that can serve many. However, I fully agree with your post. Makes it easy and efficient for HT but IMHO, far from a good tool for music listening.Audyssey is great...for home theater. The biggest improvement was how it cleaned up the low end. Can't say I like music through any receiver or pre-pro though.DARE TO SOAR:
