Pioneer Turntable
Pycroft
I have been looking at upgrading a turntable. I know nothing about tables/cartridges, etc.
Is this any good? http://cnj.craigslist.org/ele/2690749947.html
James
James
2 Channel/HT:
Sony SS-M9 P's (ES version)
Sony SS-M1CN Center Channel
Polk RT800 Surround Speakers
Odyssey Stratos Dual Mono Amplifiers
TAD 150 Signature Tube Preamp
Harman Kardon HK354
Sony SACD Player
Harman Kardon HK354
Sony SACD Player
Post edited by Pycroft on
I don't know much about that model but I have a cassette deck that matches (CT-6R) if interested.
StanStan
Main 2ch:
HT:
Other stuff:
Grab it if it works as it should. These tend to be finicky though. Linear tracking is my favorite way to spin a record.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
Pass, way better deals out there.
+1, you should try to find a nice belt drive TT instead of a direct drive. I would also look for some with better overall condition.Pass, way better deals out there.DARE TO SOAR:
I agree that the price is too high but the linear tracking is nice. I've had those tables before and you get no tracking error in the play back. This actually extends the life of your records and doesn't wear our the grooves in your records like a standard tone arm. Yeah, offer $75, it probably wasn't over 200 or so new. It was made for 2 years 1981-82. If you buy it get a new cartridge.
that asking price is way to high..... as mentioned.. there are better vintage tables out there..PolkFest 2012, who's going>?
Theoretically true, if the lin-tracker actually tracks, but, IMO, it's far simpler to assure pivot tone arms are properly tracking, and when they are, groove wear is negligible.I agree that the price is too high but the linear tracking is nice. I've had those tables before and you get no tracking error in the play back. This actually extends the life of your records and doesn't wear our the grooves in your records like a standard tone arm. Yeah, offer $75, it probably wasn't over 200 or so new. It was made for 2 years 1981-82. If you buy it get a new cartridge.More later,
Tour...
Vox Copuli
Thanks for the info. Can someone assume I know NOTHING about EVERYTHING (It's true) and let me know what linear tracking is, opposed to belt driven?2 Channel/HT:
Harman Kardon HK354
Sony SACD Player -
Linear tracking is a type of tone arm. The arm moves sideways across the record instead of on a pivot.
Belt drive is a type of drive, and the drive is what spins the thing you set the record on (platter). The main types of drives are belt, direct, and rim. There's also exotic types like magnetic induction and I'm sure others.
Belt drive uses a belt that goes around the motor and platter. Direct drive has the motor directly turning the platter. Rim drive uses a wheel that touches the rim of the platter.
That's basically it.Turntable: Empire 208
Arm: Rega 300
Cart: Shelter 501 III
Phono Pre: dsachs consulting
Digital: Marantz SACD 30n
Pre: Conrad Johnson ET3 SE
Speakers: SDA 2.3TL, heavily modified -
The PLL-800 was about 700 bucks new. The PLL-1000 is the one to have as this was Pioneer's top table back in the day.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
Price is a bit steep but Pioneer Tracking Arms were awesome sounding in there day. I would pass on this though.
nooshinjohn wrote: »The PLL-800 was about 700 bucks new. The PLL-1000 is the one to have as this was Pioneer's top table back in the day.
I don't doubt you, but that's hard to believe. The table looks so 'cheap' in the Pic. Cheaper looking than my entry level Technics?
I had and liked the PL-1000 Pioneer TT back in the early-mid 80's; though I preferred my later acquired Yamaha PX-3.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
My PX-3 has a permanent home with me. It would be tough to replace with anything close for less than 5k. Linear tracking is the best way to play a record IMHO. Has anyone made a linear tracker with a belt driven platter? That would be the best of both right there.
This Pioneer is not a bad table. I remember drooling over them when they were new, but it was way out of reach for a 15 year old. Today there is better out there, but if it works and can be had for 75.00 or 100.00, it is still a very good table.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
nooshinjohn wrote: »This Pioneer is not a bad table.... Today there is better out there, but if it works and can be had for 75.00 or 100.00, it is still a very good table.
I agree with John, it is a decent table if bought for around $75. I do prefer some of the other vintage Pioneers, both belt and direct drive. One thing to consider when buying a vintage TT is that linear tracking is one more motorized mechanism that can go bad/require maintenance.
FYI, he's selling it on eBay as well:
http://www.ebay.com/itm/Clean-Pioneer-PL-L800-Turntable-Original-Box-Manuals-/230698134104?pt=Vintage_Electronics_R2&hash=item35b6ae2a58 -
I thought the linear tables were better as well. They just seemed a little more neutral, with a blacker background. I could kick myself sideways twice for selling that PX-3, as well as it's later acquired PF-800.
The PL-1000 was much lighter/flimsy and plasticy than the Yamaha, which had very solid build all the way around.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2 -
When records are cut, I believe they are cut on a linear lathe. A linear tracking table plays records the way they were cut. Groove wear is not negligible or else they would not have anti skate and tracking error tech built into the pivoting arm table. When listening to records that have have repeated plays, a lot of times the tracks closest to the label can have a lot more distortion in them due to groove wear caused by tracking errors inherent in pivoting arms.
While it true linear tracking tables have more moving parts and are probably computer controlled as far as the arm goes, I personally think they produce superior sound from LP's due to the design. -
Browns Mills is lowlife central. Pass all day long son.
I didn't notice the seller was in Browns Mills, Steer clear. I wouldn't trust anyone in that area.
This has been posted before but... Here is a link to an interesting look into how records were made. Things may have change some since then.
http://www.archive.org/details/SoundAndTheSStan
Main 2ch:
HT:
Other stuff:
James - clear your inbox!
All Clear Big Dawg -
Never heard of Brown Mills - What's the deal? What County?
James2 Channel/HT:
Harman Kardon HK354
Sony SACD Player
