Rythmik FV15HP Direct Servo subwoofer???
danz1906
Hello,
Has anyone heard this Subwoofer? How does it compare to the usual
suspects....SVS...Element Design? Would you say it's more of a HT sub?
Thanks,
Danz
Thanks,
Danz
Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
M&K MX-70 Sub for Music
Odyssey Mono-Blocs
SVS Ultra-13 Gloss Black:D
Linn AV5120 Center
Linn AV5140 Rears
Odyssey Mono-Blocs
Post edited by danz1906 on
Most musical sub I have ever heard. It's music first, not HT. The craftsmanship is top notch.
SolidSqual wrote: »Most musical sub I have ever heard. It's music first, not HT. The craftsmanship is top notch.
That's good to know,if it good on Music it should be able to handle HT.
Have you heard it on HT???Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
Odyssey Mono-Blocs
SVS Ultra-13 Gloss Black:D -
Anymore thought on this Sub????Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
Odyssey Mono-Blocs
You should seek out a local resource for this sub. Whether the manufacturer has a forums or maybe something larger like avsforums. You'll get more answers to your questions from there then here I'm sure. The only advice will be from users who DO own this exact model.
I have dual Rythmik F12SE's and love them. They are great for music and HT. They'll be in my system for many years to come.
I used to have one of their 12" DIY servo sub and the downfiring 15" sub finished in gloss piano black. Both were among the most musical and accurate sounding subs I've heard. They didn't match the output of my Epik Castle, but that's not what they were designed for. Regardless of music or HT, if you want sound quality first Rythmik will give it to you. In a large room you will need at least two, but in a small to medium sized room they're very hard to beat for SQ.
Dual must be Sweet!Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
Odyssey Mono-Blocs
Agreed, my next Sub will be Dual.......Rythmik's or SVS........Maybe JL Audio F113....I really want to hear the New REL G1!Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
Odyssey Mono-Blocs
