Speaker Cable Wiring Construction Topology
inspiredsports
inspiredsports Posts: 5,502
I landed some David Manley/VTL cable a while back and am going to have it turned into speaker cable.
Here's what VTL has written tabout the wire:
"The VTL cable consists of a twisted array of five Teflon-insulated conductors: three legs of 18ga OFC solid-core and two of 20ga stranded silver-plated OFC, all encased in a braided shield.
For use as interconnect, VTL advises tying a solid-core and a twisted leg together for signal, tying another solid-core and stranded leg together for ground, and terminating the third solid-core leg plus overall shield to ground at the load end only.
For speaker wire, two configurations are given:
-- the first is to tie all five legs together along with the shield and use this for the positive side of the cable (another such leg is used for return, or negative)
-- the second is to tie two solid-cores and a stranded together for positive, and the remaining solid-core and stranded legs plus shield together for negative."
Concerning the speaker wire configurations, does anyone know of pros or cons of either method in regard to using them between my VTL amp and SDA's?
Conrad Johnson PV-5 w/mods
MF x-DAC V8, HAInfo NG27
NAD SS rigs w/mods
GIK panels
Post edited by inspiredsports on
  • kcoc321
    kcoc321 Posts: 1,788
    edited October 2011
  • olddog
    olddog Posts: 10
    edited November 2011
    Personaly, I have tried many special speaker wires. At less than a 12' run I could not tell the diff with any of them against plain monster!?! Now on the other hand on the IC's wire type and build made huge audible diffrences.
  • inspiredsports
    olddog wrote: »
    No where in my original post did I ask for an opinion about the efficacy of speaker cable runs greater than, less than or equal to 12' compared to your particular reference cable.
    I asked for opinions about 2 specific wiring schemes.
    Do you have any experience with the specific configurations I posted?
    NAD SS rigs w/mods
    GIK panels
    F1nut Posts: 51,915
    The first will net an overall increase in gauge over the second option. I also like the idea of having equal gauge wire for the positive and negative.
    Whether one or the other sounds better or not, I couldn't say.
    I didn't know that the old VTL offered speaker wire, any chance of a pic?
  • SDA1C
    SDA1C Posts: 2,072
    Im not big on the idea of the majority of the cable going to the positive side. If/when I get stuck with 2 different gauges I put the larger on the ground side. I also know that connecting shield to the load end only will create a field barrier, if you will, that could very likely protect the signal from outside interference.
    Too much **** to list....
  • CoolJazz
    CoolJazz Posts: 572
    SDA1C wrote: »
    Correctly called a drain...to seperate the use from grounding. It's good to use descriptive terms that avoid confusion.
    CJ
    A so called science type proudly says... "I do realize that I would fool myself all the time, about listening conclusions and many other observations, if I did listen before buying. That’s why I don’t, I bought all of my current gear based on technical parameters alone, such as specs and measurements."
    More amazing Internet Science Pink Panther wisdom..."My DAC has since been upgraded from Mark Levinson to Topping."
  • inspiredsports
    Absolutely . . .
    Rather than tie up Polk resources, I've published to http://www.inspiredsports.com/audio/vtl-wire
    I've written down what I know so far and have posted 5 thumbnails that you can click on for an expanded detail view.
    NAD SS rigs w/mods
    GIK panels
  • Tour2ma
    Tour2ma Posts: 10,177
    edited December 2011
    No where I]sic[/I in my original post did I ask for an opinion about the efficacy of speaker cable runs greater than, less than or equal to 12' compared to your particular reference cable.
    Well, that ought to make sure it's a long time till olddog makes his 11th post...
    At any rate...
    Have to assume you have enough wire to do the four runs needed for Option 1, so why not do two runs that way, a third using the Option 2 method and hold the 4th in reserve until you complete a L-ch vs R-ch (and vice-versa) shoot-out? It's not like the loser(s) couldn't be reconfigured as needed...
    Not sure if SDA's would make it easier or harder to pick a winner, but believe you have non-SDA speaks to play with as well.
    EDIT: Suggest you add a ruler or some common object to give some scale to the wire in the Web-site pics...
    More later,
    Tour...
    Vox Copuli
