Laser Cleaner?
Mr. Sharpe
I have 3 DVD players and one Cd player, all of which have never had the lasers cleaned. one is from 1988 and I'm sure it needs it.
I know a lot of you folks own some High-end equipment/Cd players and was just wondering which one you've tried.
If this is one of those "they all work" things just lemme know
Home theater:
43” Westinghouse Displayer
Marantz UD-7007 Player
Emotiva MC-700 Processor
Adcom GFA-5006 Amplifier
Parasound Zamp Amplifier
Ethereal ESO-1 Power Conditioner
Klipsch RC-10 Center
Klipsch R34c Fronts
Klipsch RB-41 Surrounds
Polk audio PSW-505
Stereo:
Polk audio RTA-12c’s fully upgraded crossovers
DIY 12tc braided speaker cables
Denon DVD-5910ci Spinner
Parasound P6 Preamplifer
Parasound HCA -1500a Amplifier
Klipsch R34c Fronts
Polk audio PSW-505
Stereo:
Post edited by Mr. Sharpe on
As long as they're working as they should I'd leave them alone!TO ERR IS HUMAN. TO FORGIVE IS CANINE.
ah ok then sounds good. I've read some reviews that say they leave the players not working at all so staying away sounds like a winner to me.Home theater:
Klipsch R34c Fronts
Polk audio PSW-505
Stereo:
Parasound HCA -1500a Amplifier -
A very wise man once said, "If it ain't broke don't try to fix it."
Just thought I'd ask and I got my answers
Home theater:
Klipsch R34c Fronts
Polk audio PSW-505
Stereo:
The other day the dollar store they were selling laser cleaning discs. It was a CD with 2 small brushes mounted to it. I think it came with a small bottle of cleaning fluid. Maybe you should try one. :biggrin:
NO!! Don't, they can actually ruin it permanetly, I've seen it too many times, those things should be burned on a turntableThe other day the dollar store they were selling laser cleaning discs. It was a CD with 2 small brushes mounted to it. I think it came with a small bottle of cleaning fluid. Maybe you should try one. :biggrin:
On older transports, the usual cause is the laser dying or the sled mechanism failing. Unless you're a heavy smoker and have tons of dust and debis around them, they rarely get dirty enough to not read a disk. Just my 2 nickels.Thorens TD125MKII, SME3009,Shure V15/ Teac V-8000S, Denon DN-790R cass, Teac 3340 RtR decks, Onix CD2...Sumo Electra Plus pre>SAE A1001 amp>Martin Logan Summit's -
haha, I got Stuwee, like I said there are many a positive review on them but the negative ones are what deter me from getting one bc I have a Denon DVD2800, Magnavox CDB482 both I use for music and a Pioneer DV-578A and I really don't even want to chance it. Like I said, was just axin:loneranger:Home theater:
Klipsch R34c Fronts
Polk audio PSW-505
Stereo:
