TV Console?
I picked up a pair of RTI A7s and a CSI A6 and they should great. The only issue is that my current TV console doesn't have space for the beefy CSI A6 speaker. Any suggestions for a nice wood TV console that can comfortably hold the CSI A6? I'd prefer something that has a dedicated spot for a center channel. Thanks.
Post edited by ajiva on
Do some web research, I'm sure you can find something.If you can't hear a difference, don't waste your money.
I'm a fan, and future owner of Salamander. I found there was nothing local (i.e. furniture stores) that had anything more than a couple inches for a soundbar center.
I'd recommend checking out Salamander, if not more than just to give you an idea of what you're really looking for in a setup. They are pricey, so it might not be your first choice - but I've researched and found them to be the most versatile.
http://www.salamanderdesigns.com/65" Sony X900 (XBR-65X900E)
Pioneer Elite SC-37
Polk Monitor 70's (2)
Polk Monitor 40's (4)
Polk Monitor CS2
Polk DSW Pro 660wi
Oppo BDP-93
Squeezebox Duet
Belkin PureAV PF60
Dish Network "The Hoppa" -
Standout Designs, real wood and large center speaker space. Not cheap though.
http://www.standoutdesigns.com/store/pc/Haven-Solid-Wood-AV-Consoles-c47.htmLarry -
Do it the old way and build one to your own specs or hire a finish carpenter to build it for you. Either way it will be better and cheaper than overpriced home theatre console.
I found mine at Costco. The manufacturer is Bayside furnishings. The model is Marino 66" TV console w/swinging floater. It holds my CS2 pretty easy and since it's off to the side, I just angle it a bit. It hides behind the fabric door and sounds very clear, no muffling.
Heres a look;
Set up:
Marantz AV8802A - Sources: BRP Panasonic 9000/CDP Emotiva ERC 3 - Display: LG OLED EVO 83 C3 - Amplification: Emotiva XPA-DR3, XPA-6, XPA-2 x 2 - Speakers: Focal/PolkAudio, Mains/2ch - Kanta No2, C - LSiM706, SS - LSiM702, WS - RTiA9, RS - RTiA9, FH - RTiA3 - Subs: Epik Empires x 2
Cables: AQ McKenzie XLR's from CDP to AVP to amp for 2ch, Emotiva XLR's for the rest - Douglasconnection: Furutech Alpha 36 12g speaker wire for 2ch, Furez 10g speaker wire for the rest - AQ Forest48 HDMI for the display, AQ Carbon48 HDMI from BRP to AVP - VR3 filtered power cables for CDP, BRP and AVP, Emotiva power cables for the amps - AudioQuest 505 power conditioner.
When I was young, I was Superman but now that old age has gotten the best of me I'm only Batman -
My TV sits on top of the center with a large piece of felt between them, works perfectly.
I have a Standoutdesign console, N702 Plus now called the XL, in cinnamon and like it very much. With the back extension, for the amp, it fits all the equipment in my signature with a little room to spare. To me it looks like nice furniture as opposed to just a TV console.AVR: Elite VSX-21TXH
Amplifier: B&K 7250 Series ii
Misc: Velodyne SMS-1
Mains: RTi-10
Center: CSi-5
Rear: Boston DSi460
Sub: SVS PC-Ultra
TV: Panasonic TC-P58V10
DVD: Panasonic DMP-BD60K
