TV Console?
ajiva
ajiva Posts: 5
edited October 2011 in Speakers
I picked up a pair of RTI A7s and a CSI A6 and they should great. The only issue is that my current TV console doesn't have space for the beefy CSI A6 speaker. Any suggestions for a nice wood TV console that can comfortably hold the CSI A6? I'd prefer something that has a dedicated spot for a center channel. Thanks.
Post edited by ajiva on
  • decal
    decal Posts: 3,205
    edited October 2011
    Do some web research, I'm sure you can find something.
  • Glowrdr
    Glowrdr Posts: 1,103
    edited October 2011
    I'm a fan, and future owner of Salamander. I found there was nothing local (i.e. furniture stores) that had anything more than a couple inches for a soundbar center.
    I'd recommend checking out Salamander, if not more than just to give you an idea of what you're really looking for in a setup. They are pricey, so it might not be your first choice - but I've researched and found them to be the most versatile.
    http://www.salamanderdesigns.com/
    65" Sony X900 (XBR-65X900E)
    Pioneer Elite SC-37
    Polk Monitor 70's (2)
    Polk Monitor 40's (4)
    Polk Monitor CS2
    Polk DSW Pro 660wi
    Oppo BDP-93
    Squeezebox Duet
    Belkin PureAV PF60
    Dish Network "The Hoppa"
  • maggiefan
    maggiefan Posts: 223
    edited October 2011
    Standout Designs, real wood and large center speaker space. Not cheap though.
    http://www.standoutdesigns.com/store/pc/Haven-Solid-Wood-AV-Consoles-c47.htm
    Larry
  • chumlie
    chumlie Posts: 8,658
    edited October 2011
    Do it the old way and build one to your own specs or hire a finish carpenter to build it for you. Either way it will be better and cheaper than overpriced home theatre console.
  • Geoff4rfc
    Geoff4rfc Posts: 2,805
    edited October 2011
    I found mine at Costco. The manufacturer is Bayside furnishings. The model is Marino 66" TV console w/swinging floater. It holds my CS2 pretty easy and since it's off to the side, I just angle it a bit. It hides behind the fabric door and sounds very clear, no muffling.
    Heres a look;
    Source: BRP Panasonic UB9000, CDP Emotiva ERC3 - Display: LG OLED EVO 83 C3 - Pre/Pro: Marantz 8802A - Amplification: Emotiva XPA-DR3, XPA-2 x 2, XPA-6, Speakers, Mains/2ch-Focal Kanta No2's, C-LSiM706, S-702F/X, RS-RTiA9's, WS-RTiA9's, FH-RTiA3's, Subs - Epik Empire x 2
    Cables: AudioQuest McKenzie XLR's/CDP/Amp, Carbon 48/BRP, Forest 48/Display, 2 channel speaker cable: Furutech FS Alpha 36 12AWG PCOCC Single Crystal (Douglas Connection)
  • rebuy
    rebuy Posts: 695
    edited October 2011
    My TV sits on top of the center with a large piece of felt between them, works perfectly.
  • dwd999
    dwd999 Posts: 8
    edited October 2011
    If you're looking for value and selection try
    www.wayfair.com
  • MADGSF
    MADGSF Posts: 603
    edited October 2011
    I have a Standoutdesign console, N702 Plus now called the XL, in cinnamon and like it very much. With the back extension, for the amp, it fits all the equipment in my signature with a little room to spare. To me it looks like nice furniture as opposed to just a TV console.
    AVR: Elite VSX-21TXH
    Amplifier: B&K 7250 Series ii
    Misc: Velodyne SMS-1
    Mains: RTi-10
    Center: CSi-5
    Rear: Boston DSi460
    Sub: SVS PC-Ultra
    TV: Panasonic TC-P58V10
    DVD: Panasonic DMP-BD60K
