Looking for advice for amp with SDA 2B
gmcman
gmcman Posts: 1,859
edited October 2011 in Electronics
I've been a big fan of Yamaha amps, mainly the MX series, but I have read that these may be overly bright or just not an ideal match for these speakers.
I want to plan for an amp for when I have done the TL mod. I will be using this inconjunction with a Yamaha CX-1000 preamp mainly for turntable use. Would like to stay under $500 if possible, don't mind used or recapping if necessary.
Doesn't need to be a Yammy, just lookng for something that doesn't take the 2B away from it's intended sound.
Post edited by gmcman on
  • gmcman
    gmcman Posts: 1,859
    edited October 2011
    I guess when I state "under $500" it's apparent pretty much anything will be used. The thought of staying vintage is an option, i'm just after the best sound from a respectable price point.
    Would finding a 20YO receiver that needs a recap be a better choice than a newer Rotel, Parasound, etc? I've heard some seriously powerful receivers from the 80's and assume that with a good recap they would really shine.
    Do the newer crop of amps lean on the bright side for the RDO198? I really don't want to pursue the tube route unless they are just the perfect match for these speakers.
    heiney9 Posts: 25,501
    edited October 2011
    gmcman wrote: »
    No and no. I wouldn't get an older reciever to power them.
    A good amp will make them shine and the "newer crop" of amps aren't bright, what I mean by that is just because it's new doesn't mean it's bright sounding. There are plenty of "bright" sounding amps from all genre's.
    Rotel
    Parasound
    B & K
    Adcom
    Carver
    Acurus
    NAD
    Cambridge
    There are literally about 20-25 choices
    This would be a great match.
    http://www.audiogon.com/cgi-bin/cls.pl?ampstran&1324036991&/NAD-C272
    Personally I sold Yamaha gear back in the 80's and 90's and never thought much of it, still don't think it's all that great so I wouldn't personally recommend another Yammy amp.
    P.s. I'd stay away, far away from Emotiva as well.
  • gmcman
    gmcman Posts: 1,859
    edited October 2011
    That's a good price for the NAD, thanks.
    Probably should have asked "what amps don't mate well with the 2B". I'll search around, missed a MX830 that went for about $175 but everything happens for a reason.
  • gmcman
    gmcman Posts: 1,859
    edited October 2011
    Well, taking a chance on a MX-1000 that apparently is "not working". I have a gut feeling it is and the seller tried to use it as a receiver and has no knowledge of it.
    The unit powers up so we'll see, for $280 I think it's worth a chance.
