Building my own Audio/Equipment Rack
Toolfan66
Well I have mentioned in a couple of threads about building my own Rack and I thought I would share what I have done so far I should have it up and going by the end of next week.
I will say that I was leaning on buying one from Adona as they have some really nice Rack's so I used one of there models as that was the one I was really wanting as I liked the idea of having a flexable rack. well I didn't want to shell out that kind of coin for a 5 tier rack as I know I could build two or three of them for that price.
I did call them and order my spikes from them as the cost of brass has shot to the moon and I couldn't make them for the price I could buy them. I will say they are very helpful and he thought it was cool I was taking on the project.
So what I did was make 8 of each size of pillars at:
3"
5"
6"
7"
8"
9"
10"
11"
12"
13"
I wanted to have extra sizes on hand so I can mod this at anytime if needed or just wanted a different look.
I also like the idea of having everything spiked I really like the look. I will also have 1" thick acrylic for all shelves, this cost me more then all the other materials combined. Each shelve will measure 19" x 24"
Here is a link to their website to give you an idea of what mine will kind of look like.
http://www.adonacorporation.com/av45cs4.html
3"
5"
6"
7"
8"
9"
10"
11"
12"
13"
Post edited by Toolfan66 on
I hate you!Main Rig-Realistic AM/FM Record player 8 track boasting 4 WPC
I’M OFFENDED!!!! -
Here is some of my parts in the raw I am using aluminum for the pillars with steel nut plates on the inside for the cross members..
Ya think it'll be sturdy enough?????
I’M OFFENDED!!!! -
I welded the end caps on one of them today to see how it would finish out, tomorrow I am going to the shop to get as many done as I can. I would like to see this at paint by Tuesday so I can have it by Friday.
With the way I machined these I can go side to side as well as up, Like I said I want this to be flexable to do what I want. I really didn't want to be restricted to my needs now or in the future by my rack. also what is nice is if I need to fab anything for it I can do so and it will match what I have now but I believe I built enough parts to do whatever I will need it to do.. -
Haha!! Yeah I think it will take what ever I put on it.. -
My plan is to have a 6 tier rack with 2 amp stands.
You can see the cost of a 5 tier rack from Adona I will have just under $1000 out of pocket for a 6 tier rack with 2 amp stands.
Keep in mind the small pieces came out of drop material, and my buddy at the paint shop will paint it all for free.
I do want to say the prices from Adona are a very fair price for whats involved to get them made.. -
:question:Will these be available like the rings sir?Main Rig-Realistic AM/FM Record player 8 track boasting 4 WPC
I’M OFFENDED!!!! -
Just today:
I went out to my man cave and reorganized some stuff to accomodate a new to me Bello rack, and you post this. I'm still really happy with this rack I picked up from GoodWill for 16.00 a month ago. It was dirty and I thought rusty but it was just grime...(lol).
It cleaned up really well today.
Another awsome project you've started and mad skills from you again Larry.
We're not supposed to ENVY people but your skills with metal working sure makes a few of us just that. I'll have to settle with doing things out of wood for the things in my imagination. As long as we're creating....we are living...some great thinker said.
Your cost is still $$$$ with so much kind-of free material and extras but.... I built a 12' long entertainment wall unit in 3 sections. Wheels, lights and glass shelves and pocket doors. I got alot at crazily reduced prices but the total was still around 750.00. I know what your saying about comparison from buying or building. We're still saving a ton doing it ourselves. And the joy of knowing you designed and created your projects with your own hands is really gratifying beyond what most will never know.
I'll be watching this thread too.
Must not envy..must not envy..LOLMost people just listen to music and watch movies. I EXPERIENCE them.
Good job Larry...you got skills!
Looks great!
That looks great!"Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer
Are you done yet? :biggrin:"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Very nice! Thanks for sharing.
Thanks Guys!! Just got home I finished all the pillars. welding,grinding,ready for paint!! I have two more cross members to build then everything is off to paint!!
Glad I had a couple of welders in the shop to help out a little otherwise I would still be there.. -
Mad skills and I too hate you.:biggrin:Speakers: SDA-1C (most all the goodies)
You can see where I machined a counterbore for the brass piece to fit in for the spikes..
Nice
I will be building a new set up myself, hopefully this winter and will submit before and after pics when done.
New set up will start with DVD shelving/bookcase with shelves that will pull out if wanted.
My idea all stems around the wall I knocked out between the great room and dining room of my single level ranch.
The header has pine 1x12's with a 1x4 underside cap and 1x4 side posts.
On one side, the great room is actually wider and will fit 2 1x12's as a back to the shelving unit, right next to the header and actually tie it in nicely.
I will use 1x12's as sides.
Then, 1x12's as shelf support struts, every 8.25 inches.
Then, 1x12's that can slide in or out as needed, in case we use it for other than DVD's one day.
If that works out, then a similar set up on the old dining room side, only taking up the entire wall, and of course different width and height shelving, also removable to change with the times as they do.Onkyo TX-NR636
Main - polkaudio Monitor 60's
Center - polkaudio CSI A6
Sub - polkaudio PSW10
Sub2 - polkaudio PSW505
Surrounds - polkaudio Monitor 40 series II
Front Height - polkaudio Monitor 40's
Audio Outdoors
Pioneer VSX 406 - polkaudio Atrium 5
Shed
Sony junker str-dn2010 with Sony bookshelf floor models and polkaudio R150's
Shed 2
Nakamichi soundbar -
Are you planning on filling the aluminum tubing with anything like sand? Also just curious but what did parts cost you? I am very jealous of your skills and connections :cheesygrin:.
Looking super good, planning on black or another color?"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
I don't plan on filling the aluminum pillars with sand to messy, I will more then likely sqiurt some expansion foam sealant in them.
Lead shot would be nice but I didn't plan for that.. -
that is awesome dudeOnkyo TX-NR636
Audio Outdoors
Shed
Shed 2
Lead shot would be better. That sand looks awesome. You do amazing work.
I sure hate having my rig torn down!! Sure hope paint comes through tomorrow..
I'm surprised you didn't carve it out of a single titanium billet
Conrad Johnson PV-5 w/mods
MF x-DAC V8, HAInfo NG27
NAD SS rigs w/mods
GIK panels -
Good start will do some more tomorrow after work.. -
I want a pair of those to put my amps on. Those are stunning!:cool::cool:
:twisted: so coolpandora charms australia Online, Buy pandora bracelets australia with BEST PRICES, Huge Collections of Pandora, Fast Delivery, Free Shipping!
